Rear Taillight LED Turn Signals?
I love the look of the LED brake lights, but the stock turn signals just don't seem right with the standard bulb. I searched azine, couldnt find much. Does anyone have a DIY to swap out the stock taillight turn signals with a small LED board to give it a consistent look? Thanks
Any 7443 bulb will fit? It will take 5 minutes to replace both. Found mine on eBay for 22$ shipped. Check out this thread by Roger to eliminate hyper flash without buying separate resistors for each turn signal the hardest part is getting the relay out of the fuse panel. https://acurazine.com/forums/3g-tl-2004-2008-93/g-109-diy-eliminate-led-bulb-induced-hyper-flashing-without-load-resistors-815219/
Stoianoff31 (03-08-2012)
rockyboy
12-06-2022 02:29 PM
