Rear Lip Spoiler Install, No Body Told Me.......
TL Cruiser/Red Wing Rider
Hey! No One Said I Had To Change Out The Deck lid Spring. And No One said I Had To Drill My Trunk. I Thought It was held In Place With Sticky Tape. Man That Little Spring Was A Mother To Get back On. Still Havent Decided To Drill My Trunk Yet. I might Add More Sticky Stuff To It.
It Will Still Be Worth It.
:ar15: :bigun2:
:ar15: :bigun2:
Originally Posted by 1hottl
DRILL...DRILL...DRILL...DRILL!!!!!!!!!!!!!!!!!!!!
Double stick tape can't do everything!?!?!?!
:ar15: :bigun2:
:ar15: :bigun2:
Originally Posted by need4spd
M5 spoiler is held on by tape :toothless
an Acura has-been
Originally Posted by dsc888
Yeah, the one on my TRD Camry kit is only held on by 3M double sided tape also. It's never come loose so as long as you use alcohol to prep the trunk first and install at 70 degrees.
never stops!
Actually after realising the quality of the double sided tape they used in headliner, Acura changed the design to make sure the wing does not fly off on the G35 behind you and stick on its grill like a moustach.
Yes. You can see the installation instructions here http://www.handa-accessories.com/tl.html
What's a TL?
Don't worry about it. Just make sure you mark the holes carefully and start off a smaller drill bit designed to go through metal. Once you get it correct then, use the bit of the correct size. Be sure to use touch up paint on the exposed metal to prevent rust. One bit of advice I know from first hand experience on my Camry's lip spoiler is to have some else hold the spoiler in place while marking off all the edges with masking tape. This will help to make sure that your spoiler is centered on the trunk lid. The double stick tape looses its effectiveness quite quickly if you yank it off after adhering it if you make a mistake. Good luck.
By the way, changing the spring may not have been mentioned because it is not really necessary...the trunk still pops open via the remote even with the original spring (just does not pop so high).
Team Anthracite Member
If you don't drill it - just promise us you won't post again in a few weeks complaining that your lip did not stay on....unless you have some funny pics of it sticking out of the guys grill behind you!!
...drill it - it is no big deal.
GÜNnµ ¡Ï
:ar15: :bigun2:
:ar15: :bigun2:
tell me where you live so i can pass by and just yank that shit out!! and paint it for me!
DRILLL DRILL DRILL
09-04-2015 08:03 AM
