Rear license plate holes
Just purchased a 2004 TL. I went to go put my new plates on & the holes are rusted out, the screws get stuck about halfway in. Could i replace these or would i just have to clean them up?
So, you can't get the bolts out at all? Or can't get them in at all?
i'm sure you can replace them. But do you have any PB Blaster, or WD-40? That'll help at least get them in for now until you replace.
If you have a tap and die set, that would help clean up the threads as well.
Luketic (12-24-2012)
^^^yup, if tapping doesn't work, IIRC someone on this board removed that panel and used JB weld to affix new nuts to the backside of the panel. should be able to find the thread with a search. it may be in the garage, dunno.
Good luck.
BANNED
ebelp?
My first ricer
I also had a bolt snap when I first bought the car, drilled it out and had enough OK threads to get a new stainless bolt coated in lithium grease in. I didn't bother trying to fix the damaged threads as there's 4 holes, if was only 2 I would have, but I did switch all 4 to stainless and coated them in grease so it won't happen again.
![Thumbs down](https://acurazine.com/forums/images/icons/icon13.gif)
Know the time is coming when I have to deal with this. As original owner of an '06 TL, the license plate has been mounted on it for 118,000 miles and some six Michigan winters..... I checked the top screws/bolts and they are absolutely frozen in place. I'll be PB Blastin' them come springtime to see if I can budge them loose.
Meanwhile, my pal recently bought a 2006 TL and had the exact same troubles - he went through the whole process of re-tapping/etc, so at least I have someone who's "done it."
As a note to new 3G TL owners, you would be well-advised to prevent this by keeping those puppies well-lubed!
Silvermoon_Knight
10-22-2015 06:25 PM
darksky
09-05-2015 03:11 AM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
