Rear Bumper Differences..
Ok, i am a little confused about the difference between getting a TL-S rear bumper or the A-Spec bumper for my reg TL. i have googled for pics but i get nothing back. i am thinkin about an exhaust system for my car, and i would just like to know what is different about the two, pros and cons. THANKS
Originally Posted by ndabunka
Hmmm, it looks like you may new to the use of forums or bulletin boards (Since you have obviously posted a set of questions to already addressed issues multiple times). There's this thing called a "search" button. Simply click on it and enter what you are looking for and you will see a lot of results. In this case, some people have also used the Ron Jon rear end (my personal favorite) but the decision as to which rear end to use may be predicated upon your specific exhaust decision (Some exhaust REQUIRE a certain). Choose the wrong rear end and you'll find yourself cutting into it just to get your exhaust onto your car.
and...another quick question will the A-Spec read bumper hold all three exhausts: GReddy, ATLP, and stock TYPE S exhaust? thanks again
thanks. well, when i searched, i got like 98175987125987 results hahaha. read through the first 10 and i saw nothing, sry about all the new posts.
Originally Posted by csmeance
only the Type-S rear bumper will, if you have an 04-06 TL or base 07, you can buy the rear aspec kit for the 07 TL-S and cut out the necessary portions on your bumper, and still have it look great.
wait, im a lil confused. only the Type-S rear bumper? the three exhausts wont work on the A-Spec kit? i thought there was only one type of A-Spec kit...i could be wrong
04-06 = a-spec
07-08 = type-s a-spec
errrr.... pretty much 04-06 is different from 07-08. They have different rear bumpers from each other. 04-06 uses one type of a-spec kit and the 07-08 uses a different type of a-spec kit.
I think i kinda confused myself.
Happy I found this thread because I was about to post this up as well....
What body panels / lights / lip kits fit from 04-06 and 07-08?
From what I've gathered it almost all can move over? Anyone have any comparisions?
The two classes(or years between 04-60 and 07-08) differ very minimally. A lot of the difference is cosmetic(exterior) changes. If you look at the base TL(07-08) compared to the 04-06, you can find almost nothing different except the rims and the taillight from my understandings. The type-S, however, has major changes in the interior as well as exterior.
Bumpers are different
Aero kits are different
Taillights are different
Standard RearCamera
Standard Type-S Rims
Standard Fog lights (I think base 07-08s have this too, but not sure)
Standard Type-S Steering wheel
Red lighting interior design
Type-S headrests and floor mats
3.5 Liter Engine
Quad exhaust...
There are DOZENS of differences in these two classes, you really should pick up the brochures at the dealer and take a look. Too many differences to name.. I can go through a number of them, and someone else will find some more.
Standard RearCamera
3.5 Liter Engine
Quad exhaust...
94 DC4 RS LSV/Turbo
^ that many posts and not 1 picture... sheesh aziners need to put down the remote and stop watching playoff hockey and basketball
https://acurazine.com/forums/showthread.php?t=177594
Originally Posted by aznbo187
I just figured this might help a bit with those who aren't sure of the differences between the two rear under spoilers of the TL and the TL-S (A-spec kit).
This might help a bit.
This is pretty simple. The Type-S has 4 exhaust pipes so it needs a bigger opening then the base one that has two square tips. If you wanna put the type S exhaust on (which will cost a decent amount of money) you can put it on your non type S by cutting up your current bumper to get the pipes to fit and then use the Type S rear lip to cover up the hacked up stock bumper and have it look stock.
Thanks, the pics are very helpful. So, can i put the Type-S A-Spec on my 07 TL without switching to a Type-S bumper
yea...only problem is that they DONT have a A-Spec Type S lip in CGP!!!! im sooooo mad ever since i figured out...today. lol
I am doing the same thing to my CGP.
I belive the cutting on the 07-08 base is minimal compare to the big hack on the 04-06..pratically the whole bottom half.
There is difference in the exteriors from the 04-06 to the 07-08. 07-08 is wider and the bumpers are different.
But really call tim... See what he can do for you... it be cheaper than what a a dealer will charge you to paint it.
BoricuaTL
04-08-2016 01:08 PM
09-17-2015 09:01 PM
obsessedmotors
09-10-2015 10:49 AM
09-04-2015 08:03 AM
