Rear Body kit piece
Rear Body kit piece
I understand how the sides and front attach for the body kit. The rear piece confuses em though. It is only the very bottom part of the rear bumper. About 6 inches above the exhaust. When looking at my car there is no seem here to remove a piece. It looks like the entire bumper would need ot be replaced. On the front there is a seem where you can see it seperates from the rest of the bumper. Can anyone who has any idea what I am babling about explain how this works? Thanks
Moreace, it fits on the rear bumper. See these instructions if helps.
https://hon*dac**uraw*or**ld.hostasa...derspoiler.pdf
remove **
remove **
Is this hard to do? Looks like it would be obvious that it was 2 pieces and not look clean. Might just be me. Thanks for the info.
Welcome any comments on those who have done this
moreace,
check out aegirs gallery
http://www.acurainspired.com/gallery...1067&uuid=1148
i just got the full bodykit and lip spoiler installed and it makes a huge difference. the lady at the dealership kept saying that the car looked HOT.
Moreace, As you might recall, I installed the body kit myself. The rear bumper must be removed. You then install the rear UBS on the bumper. You must drills holes in the bumper. You reassemble it all as one piece. So, in your case, it would have to be removed as one piece as well. I hope this helps and that I understood your question correctly.
Anybody have trouble with the rear bumper being tightly fitted against the rear quarter panel near the wheelwell?
I'm guessing when they removed the rear bumper to install the bodykit, they did not do a good job of reinstalling. What's the easiest way to correct this? I had the same problem b4 when the bodyshop fixed the rear bumper after I was rear-ended by an onlooker
Can you get the install kit seperate. the tape screws.... whatever is needed? If I have just the piece and nothing else, how would I proceed? Thanks
cost would be good too
Zonian22
Nov 14, 2015 01:20 PM
Sep 4, 2015 08:03 AM
Zonian22
Sep 2, 2015 08:19 AM
