Re-Bake Headlights
Re-Bake Headlights
I did a great job clearing my healights, but now I want them black.
I'm just not sure if it will be more difficult melting the silicone2 ( I used about half a tube on both lamps).
Or if i will have any other problems because the lights were already in the oven at over 250 degrees.
please feel free to encorage or discourage me from doing this project.
I would test bake a cured piece of the silicone2 sealant and see how it reacts before baking the entire assembly again since that sealant is not the same as the OEM sealant.
I like to whistle in my
Ony my previous cars I've never re-baked. The silicon isn't as hard to warm up like from the factory. I would just use a hair dryer on it to warm it up and then focus on like 1/3 of the headlight/corner and pry it open. I usually did this during the summer too though
If you rebake you shouldn't need them in there as long as the first time.
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
One on the right for me
I cleared my headlights...then realized it looked pretty bad and decided to black them out. Had no problem putting them in the oven again and dealing with the silicone all over.
i thought it would be a bit harder, but i'll just go ahead & do it again when I have a free day. Probably this weekend.
\I would trade lights, but i don't want to wait.
maybe if u are in LI, but u can just contact JNC to do it
so Duplicolor semi gloss heat resistant engine enamel for best results, right?
That is the same paint that I used on mine last week...very happy with the results. I wouldn't think that you would have a problem reheating them...try a heat gun (as opposed to a lower heat standard blow dryer), it heats up quickly and it is directional to where you want to heat? I used it for the removal of my emblems and worked a hell of a lot better than using a blow dryer. Anyways, I am glad I did the painting the first go-round. I have desire to pull that front-end off again anytime soon. Good luck to ya...give some pics when you are done and let us know how the unseal / reseal goes...
it was much easier the 2nd time.
I would have done this last week but my house is being redone & my oven was removed.
I had to get this over with, so I took my lights to a friend's house.
![](http://img137.imageshack.us/img137/3206/p1010042vv2.jpg)
Bad News - moisture in the passenger side lense
![](http://img463.imageshack.us/img463/1478/blackedok5.jpg)
I had plenty of silicone left in them from the 1st time.
I still put more inside and smeared more around on the outside.
this headlight was in the taller box and tipped over from a sharp turn,
but it could've been faulty already.
When I did this the 1st time, it was raining all day & i washed the whole car very well with no problem @ all.
what is the best way to fix it? do it over??
I would just seal them again w/o baking again, but there is water inside the lense now.
Originally Posted by XjoEnX
*sigh* im going through the same problem with my driver side, last season it rained and nothing happened until now =( i dont have time to take it apart either so i think it'll start to haze. but new tl-s headlights are looking real good right about now
I would still clear & blackout the corners.
Originally Posted by rondog
![](http://www.ronjonsportdesign.com/ronjonimages/large/atls44.jpg)
for some reason the headlight fogged a bit. i washed the excess silicone off the lights & bumper right after installing them and the next day it had heavy moisture in both ends of one headlight. then it went away for a few days but it came back. then it dried up again after 3 days and I never had a problem again. it was weird, but it's okay now. there are no water spots either. i guess the silicone takes a while to dry completely, but the 1st time i cleared them it was raining all day and i washed it afterwards. it's been 5 months without any fogging.
man i loved the way the lights looked before but i am a big fan of chrome. Can you tell me how you did this? I heard you need to remove the front bumper???? Let me know the steps you take in order to do this. Thanks in advance
AmplifiedDetails
09-24-2015 02:55 PM
