The quietest starter?
Yes, the normal noise it makes when starting. But I think its too loud. Doesn't sound healthy. I had a friend that had a 2007 TL but his was not so loud. I know the 05s have different starters but still, just wondering if anyone makes one that is quieter. And I suppose that a new one of my same OEM would be quieter.. I guess.. right? Haha
haha I think I figured it out.. You guys are starving for my attention. I see. Well, while you all are getting your kicks, I'll be out and whiterock lake doing my 10 mile run in the 102 degree heat.. provided I time it correctly.... *burp*.. gotta finish my monster first though. haha
The only intelligent response so far. And what I am seeing, there are no specially made ones unless you find one like
This http://www.remyinc.com/Starters.aspx
A.D.D. has been redefined. Instead of not being able to focus, it now means, and applies to people who are starving for attention. If people don't pay attention to you, then you have an "Attention Deficit". That is the new Attention Deficit disorder
Chad, looks like everyone has caught on to what I've known for a while. And I'm sure you will do great on your run, 120lb buys usually have great cardio.
Back on topic, the noise generated by the "starter" is 90% gear noise from the starter's pinion on the flywheel/flexplate. The actual motor noise is inaudible so it's not the starter but the interaction of gears that makes the noise. You can change the pitch or the number of teeth on the flexplate (didn't acura do this in the later models?). Most cars use straight cut gears not really designed for noise reduction. You can shim the starter for proper depth of engagement which if it's wrong on your car, it can greatly reduce noise. If you have the time to get in and try different shims at different locations you can really cut down on noise.
What do you have to do to maintain weight and muscle, 8,000 calories a day?
Chapter Leader (San Antonio)
That's impressive. My goal is one marathon before I'm too old to do it. I've always been a muscular build and about 225lbs but when I started training for a marathon I lost so much weight it was scary. I didn't know how to train correctly, didn't have a team and didn't look it up on the internet so I ran 12-14 miles a day 6 days a week which I now know is very wrong. I ate 5,000 calories a day and after a couple months I was 189lbs.
What do you have to do to maintain weight and muscle, 8,000 calories a day?I really shouldn't be able to do most of what I do, but since I was young I've been playing Basketball for my school and leagues so I'm used to doing suicides 24/7 and miles when I miss free throws. I use to weigh 260lbs and was only 5'9-5'10 back then (5'11 or 6'0 right now). I lost all the fat from Interval and weight lifting (which I didn't do enough-- weight lifting-- that I lost nearly all my muscle mass). Now I'm like 195-205 depending on the day and water weight.
OP, why do you even care? You hear the starter for what, two to three seconds at a time?
Yeah the starter is a tad noisier than average, but I don't see how this is a problem. It's not like the thing is running constantly as you're going down the road.
Wow. Whats up with all the trolling lately on Azine? I dont understand... Maybe he asked a stupid question, maybe he didn't, but there's no reason to blatantly be rude and obnoxious. I've been noticing this a lot lately on a lot of threads. OP's post questions and everyone just posts annoying and unnecessary responses. Just cause you're on the internet doesn't mean you have to be a d-bag. I doubt a lot of people would act this way face to face if Chad asked that question.
OP: I don't know anything about noisy or quiet starters; but I have noticed that replacing the battery with a fresh new one seems to cause the starter to spin a lot faster and maybe that can be interpreted as louder? Have you recently replaced the battery? Good luck either way.
Disclaimer: My post here is not directed at any one member. Just something I've noticed here on Azine lately. Everyone used to be so chill...Now some of us are acting like 16 year old civic drivers with 500 ILLEST stickers on our cars and Folger's coffee can mufflers. It really hurts the forum.
Cheers.
Cheers.
Cheers.
Cheers.
The starter died yesterday. I knew there was a problem with it. If something makes noise under the hood, or more noise than normal, It's telling you it doesn't feel well. You guys should remember that. Someone told me that 4 or 5 years ago. And he was right.
They wouldn't have been able to help or give any insight since the starter was working. I just knew something was wrong with it. The subject is not about "knowing how to work on a car". Thanks for your words of "wisdom" though.
well I just replaced the starter. Not only is it quieter, but it turns faster and sounds much more healthy. So I guess I do know how to work on my car.
Brian, I don't know about yours, but mine wouldnt fit in a persons ear.
btw, if anyone wants to see any pics of the starter and a nice pic of a cheater bar on the bottom bolt of the starter, then I have some you may be interested in seeing. It tells a lot.
takin care of Business in
try replacing your blinker fluid....when you start the car, the pump sends the fluid and this makes the noise you are hearing....i usually overfill the blinker fluid....no engine starting noise
that is actually a great idea, swoosh. i need to do another 1x3 on my blinker.
just remember, once you go synthetic you can't go back to regular fluid or it'll induce hyperflashing. no amount of resistors can cure this...i don't care how my ohm's they have.
.....Really Chad...stay your ass in ramblings.....
