Quick fog light question
Old May 1, 2004 | 08:42 PM
kazuaki's Avatar
I want to replace my bulbs. Do I need the 9006ST or the 9006XS? As I understand it the ST has a 90 degree plug and the XS has a straight plug. Thanks for the help...
Old May 2, 2004 | 01:44 AM
kazuaki's Avatar
Come on...I know somebody has an answer for me...
Old May 2, 2004 | 03:04 AM
Ron A's Avatar
Administrator
The owner's manual, on paqe 257, specifies an HB4 bulb, which is also called a 9006, for the fog lights. The illustration on page 214 of the owner's manual shows a right angle connector.
This is all the info I could find.
Old May 2, 2004 | 08:11 AM
kazuaki's Avatar
Thank you Ron. I would have looked in the owner's manual, except, I don't pick up my new TL until Tuesday
Old May 2, 2004 | 08:55 AM
Jcolbert's Avatar
I replaced my fog bulbs with PIAA Xtreme White 9006 and they work great. Big improvement over the factory bulbs.
Old May 2, 2004 | 09:08 AM
Ron A's Avatar
Administrator
I did some more checking. The 6006XS is the straight back, so it looks like you need the 6006ST, which is the right angle connector.
Old May 2, 2004 | 11:05 AM
kazuaki's Avatar
Thanks again Ron...
Old May 2, 2004 | 11:17 AM
VTECHokie's Avatar
I asked my dealership about fog lights and they said there was no fog light accessory for the TL. I found this strange as the manual discusses the option and specifically says it is for "US cars only." Also, my light control arm has a switch for fog lights. Can anyone tell me where they purchased thier fog lights, are they factory Honda/Acura, and how much do they typically cost?
Thanks,
VTECHokie
Old May 2, 2004 | 11:36 AM
VTEC=happiness's Avatar
What's a TL?
Thanks,
VTECHokie
Our "fog lights" are mounted with the HID's in the main light cluster. They are located just inside the HIDs and are activated when you twist the fog light portion of the light control arm.
Old May 2, 2004 | 11:52 AM
Ron A's Avatar
Administrator
But they only work on low beams, so turn on your lights, make sure they are on low beams, and twist the ring on the stalk. The fog lights will come on, and a little green icon of a light will come on below the zero on the tach.
Old May 2, 2004 | 12:54 PM
VTECHokie's Avatar
Thanks for the info! Makes me wonder why the dealership couldn't answer the same question while I sat in thier showroom reading the manual! I'm heading outside to check it out.
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
