Question for those driving in cold weather
Old 01-05-2012, 01:27 PM
  #41
RaviNJCLs's Avatar
Originally Posted by coykiam
if the car is under warranty then you don't need to warm it up...just slap it on SS/D/1st gear whatever then step on it!
Old 01-05-2012, 01:31 PM
  #42
Received 16,263 Likes on 11,973 Posts
BECAUSE RACECAR.
I vtak when the engine is coooooooooooooold.
Old 01-05-2012, 03:29 PM
  #43
Deerole's Avatar
warranties do expire
Old 01-05-2012, 03:32 PM
  #44
RaviNJCLs's Avatar
I think he was joking.
Old 01-05-2012, 03:33 PM
  #45
Deerole's Avatar
^^would hope so
Old 01-05-2012, 03:35 PM
  #46
^we know so.
Old 01-05-2012, 03:43 PM
  #47
The Sicilian
jspagna1's Avatar
Originally Posted by JTS97Z28
Modern vehicles DO NOT require a warm up period. The absolute best thing you can do for the car is get in, start it and drive off NORMALLY. Dont go flooring it down the street, just drive normal until all the fluids can get up to normal operating temp. Anyone that says you need to warm your car up before driving off is incorrect. Also, people that store cars and start them and let them idle for 15 minutes are doing more harm than good. Cars are not designed to be started and just idled, they are designed to be started and driven.
I agree with the majority here, start her up and maybe give the car just a little time for the cold idle to settle then be on your way normally. Your car will thanks you :-)
Hope this helps,
James
Right answer! And yes when I store my 66 Mustang, I don not start it at all till it's time to take it out in the Spring time.
Old 01-05-2012, 03:45 PM
  #48
RaviNJCLs's Avatar
Nice.
Old 01-05-2012, 03:46 PM
  #49
I like turtles
luckyjakob's Avatar
Originally Posted by ~Lefty~
Yea dude...9* here this morning when I left for work.
Damn that's cold... Dude I live in Minnesota and it's 42* here today.. WTF? Bring me some cold weather! I want some snow!
  #50
spaceboy's Avatar
depends on if i m late for work or not...it not then prob one and if yes maybe 20 to 30 sec
Old 01-05-2012, 04:22 PM
  #51
Turbonut's Avatar
James
You do realize that some modern vehicles will not shift into overdrive until the trans fluid eclipses a certain temp, and in cold weather that certainly doesn’t happen in a few miles, or even a few minutes.
On the Mustang, I would assume those cylinder walls are quite dry after sitting for 6 months so I hope you prime them first.
Old 01-05-2012, 04:39 PM
  #52
lilusadude's Avatar
it is near 70 degrees F here.... na na na na boo boo!!
Old 01-05-2012, 05:31 PM
  #53
Deerole's Avatar
^we know so.
Old 01-05-2012, 10:10 PM
  #54
I like turtles
luckyjakob's Avatar
Blah blah blah.. 42* in Minnesota is unheard of in January.. The past few years we've been rockin some -10 or -20 days
Old 01-05-2012, 11:32 PM
  #55
TL=True Love
wall e's Avatar
i listen to one entire song on the radio and then I move
Old 01-06-2012, 12:33 AM
  #56
Your Friendly Canadian
Aman's Avatar
Received 1,485 Likes on 1,049 Posts
BECAUSE RACECAR.
I've heard stories of people going WOT/redline on a completely cold engine because it supposedly sounds better. No joke.
Old 01-06-2012, 10:40 AM
  #57
coykiam's Avatar
^we know so.
lol I was too lazy to put on the red text
So...anyways, What is the best oil for the TL?
Old 01-06-2012, 01:08 PM
  #58
I like turtles
luckyjakob's Avatar
I use water instead of oil. It's cheaper
Old 01-06-2012, 01:41 PM
  #59
The Sicilian
jspagna1's Avatar
Understood, but I have never had to replace a transmission in any of my vehicles so far.
Also no on the Mustang either. It's got a late model 5.0 motor (89-93). I have done this for the last 15 years and with 17,000 mile on it now, it still rums like new and no oil consumption or smoking of any kind.
Old 01-06-2012, 06:04 PM
  #60
Turbonut's Avatar
Personal choice as it won't harm anything to let the car warm up, been doing it for 20 years with a remote starter on 3 of the cars in the household, not the TL.
I've never replaced a trans in any of my cars either, and that's with almost 2 million miles of driving.
Speaking of the Mustang, it's certainly easy and much better to prime the engine with the oil pump before starting after sitting for an extended length of time. No one said the engine would blow, rings would crack or walls disintegrate, just that's its much better to prime the engine with oil as the walls will dry with the valves opened and with the load on a dry camshaft it's a good idea to get oil circulated throughout the engine before starting.
Just like driving when cold, the Turbo car I have only allows the accelerator to partially open because of the need to get everything circulated and up to temp before normal driving, so it idles for a period of time. Also, the RedLine fluid in the trans is so thick that when the clutch is engaged in neutral when cold, the engine rpm's drop drastically.
So to each their own, drive or idle and I choose to idle the cars.
lland
10-04-2015 04:47 PM
MyGuti
09-12-2015 06:52 PM
dlknight
09-03-2015 07:54 PM
Quick Reply: Question for those driving in cold weather
