Question regarding HIDs
Knowing that our cars do not come with Auto headlight, I always keep my hids on.
My question is, what are the consequences of driving with the hids on all day? Is it like halogen bulbs where after x amount of hours, the bulb will die out?
Any feedback on this would be great.
Thanks!
Thanks!
There is no good reason not to leave the headlights on. The HIDs will last many years (if not the life of the car). I have never seen, nor heard of a car with HIDs in which the HIDs "died out" naturally. Even if they do "die out" in several years (6 or more), I think the benefits of keeping them on outweigh the cost of replacement.
Lights do cost gasoline to operate. so that's one reason to not have them on all the time. I guess you'd have to balance the possible slightly increased safety vs. the slight amount of gas used. (Rough guess: 1% less mpg, like a couple of tenths of an mpg).
The alternator is harder to turn when it is generating power. (For anyone that says it's not true "because the alternator is spinning anyway", you just found a source of free energy - why not generate power with that free energy and solve the world's energy problems?)
The DVD-A Script Guy
Originally Posted by TacoBellSauce
actually, leaving them on will do no damage
HIDs lose life span when turning on and off repeatedly
It is true that short time spans between "striking", or repeated "striking", of the bulb is worse but any cycles still count. I'm not looking to start a debate over the merits of DRLs. Lord knows there is enough controversy over that. I'm just trying to say that using HIDS as DRLs will cause more hours and cycles than not.
I used to be a big fan of DRLs but my enthusiasm waned as more and more cars had them in the late 90s. It seemed that they were so common place that they weren't even noticeable. The poor motorcyclists were had the most to gripe about. They became invisible again. Turn your headlights on in the dark and the rain. If you can't do that then turn in your license.
What do yo want from me. I still shift a car. Imagine all that extra work. God forbid I should have to turn on headlights.
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
05 C230K & 09 135i 6MT
I am a fan of DRL but not low-beam full intensity DRL. I think 75% intensity, high beam only DRL looks good on cars. If I can't have that, I won't run headlights at all.
And Adobeman is right, there are significantly more cycles by leaving the switch to "ON" al the time. They come on when you unlock the doors, and if you don't open the door in a certain amount of time they go back off, and then come on when you open the door. Running errands and getting in and out of the car can result in many cycles during one day.
First off, I think both the bulbs and the electronics for the hids are very expensive,
at least when compaired to regular bulbs.
Anyone price an electronics module for the hids?
I added a relay to turn the fog lights on whenever the key is on, as daytime running lights. I left them at full intensity.
Brett
Brett
Originally Posted by peewee5384
Oh and just so you know those starters can be between $900 up to $1600 EACH
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Originally Posted by tfe691
WOW maybe 15 years ago. If that is true your getting ripped off who ever told you that. The ballast and ignitor together is around 350-400 per side. The starter should outlast it all.
Originally Posted by gotjesus
do you always have to buy them together? or can one of those two can break down and replace it?
NY/NJ TL Crew
1 Post
They last a long time, the only thing that you shouldnt do is play around with them by turning them off and on, off and on, off and on, or even flashing your highbeams for a long period of time because then the bulb will burn out. A murano with HID's was high beaming me with flashes for about 5-10 seconds, then one of his bulbs died so I just laughed and kept driving. Besides that, you'll be fine for a good 3 years or so
Originally Posted by arseny87
They last a long time, the only thing that you shouldnt do is play around with them by turning them off and on, off and on, off and on, or even flashing your highbeams for a long period of time because then the bulb will burn out. A murano with HID's was high beaming me with flashes for about 5-10 seconds, then one of his bulbs died so I just laughed and kept driving. Besides that, you'll be fine for a good 3 years or so ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
AmplifiedDetails
09-24-2015 02:55 PM
