Question on the climate control automatic for TL 2006
When I use climate control automatic, then climate control recirculate, the auto sign disappeared. Do I still get auto climate control without the auto sign?
Also, is there anyway I can know if the A/C is on when using climate control automatic? Climate control bothers me since I couldn't find a really confortable mode for it, or maybe I just bought the car for two weeks, hehe!
Thanks a lot for any help here!
The climate control works very well in the Auto setting. Best thing is to select an initial temperature, say 68 degrees, the select Auto. The system will do the rest. if you find it getting a might too cool, reselect the temperature up a few degrees. I find the Auto setting to be nearly ideal.
Personally, I pick a number and leave it alone. Unless it's extremely hot/cold out and I want everything on full blast when I first get going...
i agree, the climate control in the TL is one of the best i've seen. it never feels like it's blasting super loudly, which happens a lot in my dad's Lexus... so he always has it off. On the other hand, I always have mine set to 71 or maybe up and down depending on how it feels
Like the others have said, the Auto climate control is one of the best I've ever seen. In the summer I set it initially at 70 degrees and then once things cool down I set it to 72. Feels perfect and you never really feel it blowing full force.
I set it and forget it, too. The only time I ever notice it doing something is if the audio is off and I'm making lots of turns. The navi-controlled ventilation is apparent as I hear it changing vents.
IMHO Nissan makes one of the best climate controls. The TL isn't very good. I use to keep my G35 on 72 and it kept it at 72. The TL got warm at 72 so I had to go down to 68 and hope it keeps it cool. I never had to adjust the G35 ever off 72. It just worked. The TL, I am always adjusting the fan speed manually.
To the original poster, you know it's on Auto if it says "Auto" in little letters right above the temperature in the upper dash display. But there's not a light or other indicator that I've found that tells you the A/C (compressor) is on.
All the other cars I've owned had little lights to tell you the A/C is on - like the one on the "Dual" button - but not the TL.
And not to hijack the thread, but I agree the climate control is not quite as good in the TL as in some other cars I've had. For one thing, the fan doesn't blow as hard as most cars when you have it at its highest speed. I really like a flood of air, since it gets hotter than the hinges of Hell here in Texas, and the TL sometimes seems wimpy in that department. So I have to keep it set at a lot lower temp than I'm used to (like 65 degrees) to stay cool enough.
oh since we're talkin about the climate control...
how come the rear defroster doesn't turn off by itself when it's done defrosting?
my old accord's defroster turns itself off without me pushing the button again after it's done.
Originally Posted by ndx2
It disappeared because you overrode AUTO by manually choosing to recirculate, rather than having the ACC decide when to use recirc.
You'll still get the desired temperature. If the AUTO sign is off, it just means it won't control all the aspects of the HVAC system. Unless you want to chose the vents or the fan speed, it's just best to leave it on AUTO, imo
I don't think there's a light/sign that comes on while on auto, but you can hear/feel it engage... besides, if there's cold air blowing out on a hot day...
Thanks a lot for the details! One more question, when climate control's off, then I manually press the fan speed button, will A/C be on automatically?
The TL's climate control is so-so. The auto programming is way too slow to go to max fan speed when the interior is hot, and it shouldn't go to recirc until it blows the hot air out and the cabin temp starts to approach the auto setting. I end up doing it manually and it works much better. I live in SC so the interior can get seriously hot. A sunshade is a must!
It's a minor gripe, and I'm not aware of any other climate control system that's really "smarter", but there are many that react better to temp changes. The TL's climate control scheme is too conservative IMHO.
BTW, the rear defroster is on a timer but if you re-actuate it after it times out it'll stay on in "manual mode" until you turn it (or the car) off.
