Question About Installing Load Resistors
Old Mar 8, 2009 | 12:08 PM
mn2trance's Avatar
All About Trance
I'm having a problem trying to figure out how these things are suppose to be installed. I had purchased 2 resistors that look exactly like this http://www.superbrightleds.com/pdfs/...istor_info.pdf. I don't know where the blue part is suppose to be connected to. Am I suppose to hook one end where the resistor is already cut and then snap it into the wires? Or am I suppose to snap those blue things to an uncut part of wire and then put the T-Taps at the end of the part that's been cut?
I've found the thread on how to install these in the car, but not been able to find one that actually shows you how to connect them in the beginning . . . if that makes sense.
Old Mar 8, 2009 | 12:18 PM
powerflow's Avatar
Wiggy Wiggy Wiggy
I'm confused too. The linked document shows how to wire and connect.
Personally I wouldn't use those in line, push Taps. I would solder, or use crush connectors.
Be careful where you mount these. If you ever leave the hazard flasher/blinkers on for a longer duration of time, for an emergency situation for example, these resistors get super, super crazy hot. So hot, they can easily melt stuff.
Old Mar 8, 2009 | 12:25 PM
mn2trance's Avatar
All About Trance
I'm glad I'm not the only one. By looking at the diagram, it looks like the end where it's already been cut goes in one end, then you'd place the blue part over the wire that needs to be connected to and then snap everything shut. However, if I do that, wouldn't that cut into the wire when the diagram said not to do so in the first place? Thus, my confusion.
And I plan to mount these with velcros to the metal part of the car. Hopefully, they won't get too hot where it'll melt the glue from the velcro as these are the 50 watts 3 Ohm ones.
Old Mar 8, 2009 | 12:27 PM
EVOLICARUS's Avatar
http://www.acura-tsx.com/forums/showthread.php?t=637923
Old Mar 8, 2009 | 12:33 PM
powerflow's Avatar
Wiggy Wiggy Wiggy
It says do not cut, since your only tapping into the wire, not cutting/ re-routing it.
That wire only needs to pass through the push tap.
They probably think dump people will jump the gun, and just start cutting up the wire. Seems like a "dump ass disclaimer" so to say.
mn2trance's Avatar
All About Trance
^ Yeah, that's the one I had referenced with my install, but he has a different resistor than I do and he had used T-Taps whereas the ones I had gotten had included those blue things. Am I suppose to snap the turn signal wires and resistor wires in all at once or am I suppose to snap the wire from the resistor to the blue thing first and then unsnap them to snap the turn signal wires in?
Old Mar 8, 2009 | 12:38 PM
Fulani has a TL's Avatar
4 Resistors?!!!
powerflow's Avatar
Wiggy Wiggy Wiggy
I wouldn't use Velcro either. I've seen how hot these things get.
I would only mount to metal in a safe area.
Old Mar 8, 2009 | 12:40 PM
See how there are two "grooves" in the blue tap. One of those "grooves" does not go all the way through, the other one does, lay the wire from the resistor in the "groove" that does NOT go all the way through, lay the vehicle wire in the "groove" that DOES go all the way through, Close the top and press the metal down with pliers and then close with the cover.
I would put some electrical tape over it as well
Got it?
Old Mar 8, 2009 | 12:42 PM
mn2trance's Avatar
All About Trance
Originally Posted by Fulani has a TL
4 Resistors?!!!
No . . . only 2. One on each side.
Yeah, but that would mean drilling and I don't have one of those nor do I want to drill into my car again. Having to do that when I had installed the lip spoiler was painful enough.
Old Mar 8, 2009 | 12:46 PM
Self Tapping screws?
Old Mar 8, 2009 | 12:50 PM
mn2trance's Avatar
All About Trance
Got it?
OK . . . thanks. I was thinking along that line, but the disclaimer of the install threw me off.
One more thing. I saw in your How To that you said to tap into the black with silver dashes and white with silver dashes on the passenger side. However, I see 2 black with silver dashes . . . one is a single dash whereas the other one has 2 silver dashes on it. Do you remember if yours has that?
Trew's Avatar
that diagram is very easy and straight forward.
The T-Taps have 2 sections:
1 for the existing vehicle wire (turn signal) that goes into the tap,
1 that accomodates the resistor wire. Connect the resistor to the section that does not go all the way through the tap.
Once both are placed in the tap, then squeeze the metal piece with a pliers. There is no need to cut any wires when using a tap. the metal piece will shave off the insulation and make contact with the bare wire without you having to cut anything.
Lastly, don't even think of using velcro or double-sided tape to mount these. get yourself a small self-threading screw and screw the resistor into a metal panel, ensuring that no wires, upholstery or anything else can make contact with the resistor. The metal to metal contact will help dissipate the heat generated by the resistor.
Old Mar 8, 2009 | 12:52 PM
Trew's Avatar
Got it?
thanks Fulani. I like your explanation better - lol
Old Mar 8, 2009 | 12:58 PM
mn2trance's Avatar
All About Trance
Thanks for the explanation. When I saw the metal part protruding out, I thought it would cut into the wire, not splice it. I'll pick up some self tapping screws afterwards. Thanks again Fulani and Trew.
Old Mar 8, 2009 | 01:21 PM
powerflow's Avatar
Wiggy Wiggy Wiggy
To install screws, you will need to drill. Self tapping screws will only self tap threads, not actually drill through the metal efficiently.
Get a marker, center punch, hammer, drill and a drill bit. Mark where to drill the hole. Punch a slight divot on the mark, to guide the drill bit. Then drill the hole on the divot.
Old Mar 8, 2009 | 01:24 PM
01tl4tl's Avatar
drill a smaller hole than the screw you are putting in
a piece of masking tape on the metal to be drilled -keeps the drill bit from skipping around
Old Mar 8, 2009 | 01:26 PM
01tl4tl's Avatar
if you do get stuck at a long left turn stoplight-turn off the turn signal-
the person behind you WILL appreciate it--go take a look at how bright LEDS really are
and it keeps the heat down in the resistor
Old Mar 8, 2009 | 01:53 PM
mn2trance's Avatar
All About Trance
Woo hoo!!!! Load resistors have been installed and no more hyper flashing! Thanks again to everyone! I will have to do the drilling at a friend's house who has more power tools than I do.
Old Mar 8, 2009 | 01:54 PM
I think, it was the one with the single dashes. Best way to make sure, look at the wires that go into the connector right by the turn signal bulb, what color are those? Thats what you want
NVM you already got it
Skirmich
Sep 15, 2015 06:41 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
Mike Bertram
Sep 10, 2015 09:27 AM
asahrts
Sep 4, 2015 05:55 PM
