Purple headlight?
Old Oct 14, 2018 | 08:40 PM
Joe Foe from Buffalo's Avatar
Purple headlight?
Does anybody know why One of my headlights recently has a purple color as seen in link/ picture below? Its as bright works good as the other..
https://photos.app.goo.gl/2tJTe7tqD1gSKA4L8
Old Oct 14, 2018 | 09:11 PM
guitarplayer16's Avatar
This is an indication that the bulb is failing/failed.
Great time to upgrade to better bulbs!
Old Oct 14, 2018 | 09:16 PM
Thank you. Please let me details on what to get an how to replace. Car has 195,000 miles on it so upgrade if costs more then oem lights that worked good enough for me may not be wise.
Old Oct 14, 2018 | 09:51 PM
nfnsquared's Avatar
replace both bulbs at the same time. do a search, plenty of threads on aftermarket bulb options.
Old Oct 14, 2018 | 09:59 PM
Will Y.'s Avatar
Registered but harmless
Just buy the Osram HID OEM replacement bulb from Amazon; I paid @ $90 for a pair of the bulbs.
There are two ways to change the bulb-- removing the front bumper or turning the wheel and going in through the fender well liner for the passenger-side bulb.
I didn't want to remove the front bumper and went through the fender well liner; it took me over an hour because I was doing it by feel, and had difficulty putting the clip on the new bulb.
If you decide to change both bulbs, it may be easier to remove the front bumper and do it that way.
The two relevant threads are:
https://acurazine.com/forums/third-g...-004-a-598853/
and
https://acurazine.com/forums/third-g...-001-a-587181/
G/L.
Old Oct 14, 2018 | 11:30 PM
Here are 4 options at 4 price points:
Morimoto (TheRetrofitSource's in-house brand bulb) GREAT bang for your buck at $50: https://www.theretrofitsource.com/d2...to-xb-hid.html
Osram OEM equivalent: at $85: https://www.theretrofitsource.com/d2...arc-66240.html
Osram CBI(Cool Blue Intense) The best bulb on the market in my opinion $110: https://www.theretrofitsource.com/d2...cbi-54784.html
Phillips 85112 (Also an OEM equivalent bulb) at $85: https://www.theretrofitsource.com/d2...ips-85928.html
Pick your poison! You can't go wrong either way.
Old Oct 15, 2018 | 04:38 AM
MI6's Avatar
MI6
Great Northerner
Agreed with the above. Definitely indicative of a bulb at the end of its working life. If you can do the work yourself you’ll save a good amount of money.
Every time I’ve changed a bulb I’ve always had my front bumper off doing other things like tweaking projectors and installing clear lenses, modifying the FGL and/or the shield.
Does anyone know if the OP can swap out the bulb by pulling back the fender liner? Can he reach the bulb from there? Problem with that is if the OP hasn’t been in there before it may be hard because of the screw that keeps the plastic protective shroud on.
I’ve used all kinds of bulbs and I just swapped out my CBI’s for a pair of CBB’s. I’m still stunned at how amazing they are. With clear lenses I outshine everything and there is intense color flicker (if you like that sorta thing). At $190 they ain’t cheap but if you’re throwing down the loot for CBI’s I would spend the extra money. Always best to replace in pairs as well. I bought mine at The Retrofit Source (TRS). Place is awesome.
If you’re already going through the process of changing a bulb you might as well change it out for something brighter and safer. I do a lot of night driving, sometimes in rural areas and the safety outweighs the cost.
Old Oct 15, 2018 | 06:09 PM
Thank u every one! What is a cbb bulb? I can't find it. I could find some videos on replacing the bulbs without removing the bumper.
Old Oct 15, 2018 | 06:10 PM
Old Oct 15, 2018 | 06:12 PM
Old Oct 15, 2018 | 06:14 PM
https://www.osram.com/am/ecat/COOL%2...t/ZMP_4054558/
Available from TRS as well: Just at $190.
https://www.theretrofitsource.com/d2...66240-cbb.html
Removing that Security Torx bit from the rear cover is the hardest part of replacing bulb without removing the bumper.
Old Oct 15, 2018 | 07:15 PM
Superunknown's Avatar
Just remove the bumper, it's not that hard. I can't imagine fucking around with that security torx and the HID bulb (which needs to stay CLEAN) through the fender.
Old Oct 15, 2018 | 07:18 PM
I'm 1000% with you on it.. removing the bumper sounds more tedious/scary/harder than it really is.
Old Oct 15, 2018 | 08:35 PM
MI6's Avatar
MI6
Great Northerner
I’m not sure where/what website that is but I can say that it is very easy to get ripped off with “fake” bulbs such as those posing to be Philips bulbs from Germany.
I should probably put out a disclaimer that I don’t work for TRS, don’t know anyone there and don’t get any perks from recommending them but I have ordered thousands of dollars of parts from them over the years and they are a very reputable company. The owner is usually frequenting the site too answering questions and offering advice.
I’m sure there’s a lot of people on Acurazine that could vouch for that as well. That being said, these are the bulbs I bought and I could not be happier. The new BMW’s and Mercedes that don’t have LED headlights generally use these as OEM:
I hope this helps! Nice video btw, very useful!
Old Oct 15, 2018 | 08:52 PM
MI6's Avatar
MI6
Great Northerner
Agreed. The bumper really isn’t that difficult to get off and put back on. It also offers you plenty of room for access to mostly anything.
From the work I’ve done on projectors I say later to the Torx screw and just cut a slot in it with my Dremel and, voila, instant flathead screw. Easy to manipulate with a little stubby screw driver but to each their own.
Old Oct 15, 2018 | 10:09 PM
tlmailman's Avatar
years ago I just twisted the cap until it actually tore off from the screw. Didn't know about the screw until i joined Acurazine. still don't know why its there. The cap screws in tight, never loosened in over a decade without the torx.
Old Oct 16, 2018 | 09:10 AM
djw88's Avatar
that is the actual philips website.
philips makes the best bulbs by far in my opinion i almost always replace with philips bulbs for everything.
Old Oct 17, 2018 | 09:24 AM
Yvuru's Avatar
the bulb is probably on its way out, happened to me too
+1 for philips. the OEM bulbs were philips, so i stuck with the same brand. been running their xtreme visions for 4 years and they still work like they did on day 1
davewhodavedunn
21
Apr 28, 2010 08:01 AM
StonedCL
Feb 21, 2009 01:40 AM
Dow Jones
Dec 14, 2006 11:07 PM
sbuswell
Sep 19, 2006 04:06 AM
minkl81
Jun 23, 2006 12:14 PM
