Programming Remote
Old Apr 23, 2005 | 09:33 AM
Weekendzs's Avatar
Programming Remote
May someone please be so kind as to provide info on programming the remote for a 2004 TL. Many thanks...
Old Apr 23, 2005 | 12:32 PM
catsailr's Avatar
This worked for me:
Keyless entry remote programming for Acura
1. Turn the ignition switch ON (II).
2 Within 1-4 seconds push the transmitter lock or the unlock button.
3 Within 1-4 seconds turn the ignition switch OFF
4 Within 1-4 seconds turn the ignition switch ON (II).
5 Within 1-4 seconds push the transmitter lock or the unlock buttin.
6. Within 1-4 seconds turn the ignition switch OFF.
7. Within 1-4 seconds turn the ignition switch ON (II).
8. Within 1-4 seconds push the transmitter lock or the unlock button.
9. Within 1-4 seconds turn the ignition switch OFF.
10. Within 1-4 seconds turn the ignition switch ON (II).
11. Within 1-4 seconds push the transmitter lock or the unlock button.
12. Confirm you can hear the sound on the door lock actuators. Within 1-4 seconds, push the transmittor lock or onlock button again.
13. Within 10 sec, aim the transmitters whos codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stores. Make sure you program all transmitters you want working within 10 seconds of each other. Ones not included in this programming will no longer work.
14. Turn the ignition switch OFF, and pull out the key
15. Confirm proper operation with the new codes.
Old Apr 23, 2005 | 01:03 PM
Weekendzs's Avatar
Good looking out... I appreciate your help IT WORKED.
datadr
Mar 23, 2016 01:39 PM
eastcoastguy
Oct 29, 2015 03:00 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
