Programming Garage Door Opener
I have a 05 TL and no operators manual. Without someone telling me to do a search can someone tell me or post a link on how to program my remote to the homelink system. Thanks in advance.
Sam |
Would this work?
Try it this way: 1) Hold down the button on the garage remote AND the button on the car (pos #1) AT THE SAME TIME. 2) Stop when the red light in the car's ceiling starts blinking fast. You're done. 3) Now park the car close to the gate. Very close. 4) Find the "learning button". It's supposed to be on the motor's surface. 5) Press the learning button and run to the car. 6) Hold down the same button inside the car (pos #1) until it starts blinking fast. That works for most of the scenarios. Let us know if it works, ok? |
Originally Posted by sleeper22
(Post 14700052)
You do not have to register with Acura to see the manuals; Homelink set-up is described in the "Features" section of the manual. Your second post seems to describe setting up Homelink with a rolling-code garage door (better to have 2 people to program it rather than running back and forth ;) ); older fixed codes openers have an easier set-up. |
Will thank you very much :)
(Post 14700052)
i have a 05 tl and no operators manual. without someone telling me to do a search can someone tell me or post a link on how to program my remote to the homelink system. Thanks in advance.
Sam https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/definitve-guide-homelink-set-up-566382/ |
