Problem with installing LED interior Lights
Old Aug 2, 2010 | 08:50 PM
05TLOwner's Avatar
7th Gear
Hey guys really need help.
I was installing blue led interior lights inside my 05 tl when all of a sudden the lights turned off and now i cant turn them back on. Separately my remote transmitter also stopped working. Any ideas on what happened?
Old Aug 2, 2010 | 08:56 PM
libert69's Avatar
18psi
check the fuses...maybe something popped. check your manual for which fuses control what.
Old Aug 2, 2010 | 10:43 PM
05TLOwner's Avatar
7th Gear
Ok so the fuse is blown. where do i get a replacement fuse?
To tell you the truth...i got my license 5 days ago and my parents were nice enough to hook me up with one of their cars. I dont know shit about how cars work but im trying to figure it out. Thanks for your help btw.
Old Aug 3, 2010 | 03:26 AM
libert69's Avatar
18psi
You can get a replacement fuse at any autoparts store. Walmart would have them also.
There is a fuse box in the kick panel on the floor by the brake pedal. Check the manual to find out which fuse controls the interior lights.
Pull the fuse out that controls the interior lights and check if the the little piece of metal inside the fuse is broken. If it is, then the fuse is blown and replace with the same type. Use the number printed on the fuse to find the correct one.
Old Aug 3, 2010 | 10:54 AM
Persia-TL's Avatar
yea it could deff be that you blew out a fuse. when u take the cover off the fuse box, the back of has a layout that tells you wish fuse is what.
If you like doing electrical mods such as lighting and audio it ll be wise to invest in a test light. its a screw driver looking tool that has a sharp pointy end and a wire on the other end.
you connect the end of the wire to a ground (any part of the body of the car) and one by one test the fuses, or wires.. if there is power going to them the light in the test light will light up.. a great way to check all your fuses without keep taking them out and putting them back in.
welcome to AZ
-cheers
Old Aug 3, 2010 | 11:48 AM
05TLOwner's Avatar
7th Gear
Thanks to both.
It was a blown fuse so i went to a local auto parts store and bought a few of the same exact fuse. atm 7.5 amps. When i put in the new fuse my homelink and key started working again but my lights still wouldn't turn on. So i was going to just see if i could put my old ones back in but while i was taking out my first light, it lit up. I then kept that one in and then moved onto the others. I blew the fuse again the next light. Is there anyway i could still use these lightbulbs without blowing a fuse?
These are the ones i got.
http://cgi.ebay.com/ebaymotors/White...item1c1430bc6d
You think these only work for the type-s? That would suck.
Old Aug 3, 2010 | 12:17 PM
AMUA6's Avatar
ScoobyZINE
Bump up to a 10A fuse If it continues to blow the 10a fuse, then trash the bulbs.
Old Aug 3, 2010 | 12:27 PM
05TLOwner's Avatar
7th Gear
Just tried that and it burnt the end of the bulb off... took out that fuse right away.
Old Aug 3, 2010 | 05:21 PM
jdmap1's Avatar
5th Gear
Try messing with the metal wires sticking out the bottom of your new bulbs and move them around. LEDs on ebay are cheap but will work just fine as long as you have the patience to mess with them. I just recently replaced all of my interior ones without blowing any fuse. Make sure all the lights are off before changing them out, if its on and you plug the bulb in, that causes a current surge = blown fuse.
And damn $31 for 8 bulbs. Glord!!! I bought a pack of 10 from ebay a year ago for my bike's license plate and i only paid $8 shipped to my house. Whoa!! talk about inflation.
Old Aug 3, 2010 | 05:24 PM
jdmap1's Avatar
5th Gear
And oh, never bump your fuse size!! Its a good way to burn the whole circuit. always stick with what is recommended. those 168/191 LEDs bulb are made specifically for your interior. Also the same bulbs works on your license plates too. Very pretty at night time.
Old Aug 3, 2010 | 11:57 PM
05TLOwner's Avatar
7th Gear
So i replaced all the bulbs with the fuse out. then put the fuse in and nothing would turn on...checked a bulb and right when it turned blue i burnt the fuse again. how can i do this without burning a fuse?
Old Aug 4, 2010 | 12:13 AM
libert69's Avatar
18psi
I skimmed over the ebay listing quickly but I did not see what type or size bulbs these are. They may not be the right size/type bulb for what your putting them in. It looks like you bought 8 of the same type of bulb. Is that correct? What type are they?
use this link to find out what type of bulbs you need for the specific location you are putting them in.
http://www.sylvania.com/ConsumerProd...lacementGuide/
IMO, this is best site for buying led bulbs. Buy the good stuff first and they will last longer.
http://www.v-leds.com/
Old Aug 4, 2010 | 01:05 AM
05TLOwner's Avatar
7th Gear
Im sorry, i accidentally posted the wrong link. Here you go. They were all the same bulb in this one too.
http://cgi.ebay.com/ebaymotors/Blue-...Q5fAccessories
Old Aug 4, 2010 | 02:28 AM
libert69's Avatar
18psi
well the listing is saying that the bulbs are for the doors, front dome lights and rear dome lights. All those bulbs are 2825 size bulbs so they are saying you are getting the correct size.
I really dont know what else the problem would be. These are the bulbs I bought for those lights. http://www.v-leds.com/Interior-LED/G...-p6638587.html
They work fine for me and no problems with blown fuses. Maybe buy 1 pair from them and see what happens. Good luck
Old Aug 4, 2010 | 07:00 AM
LoveMyTL-S's Avatar
LED's must be installed one one way or one direction, as they are a diodes. Try flipping the bulb around and plug it in again (with power off). Then try them.
Old Aug 4, 2010 | 07:14 AM
Sandals's Avatar
OK THIS IS YOUR PROBLEM, in between the two front dome lights there is a switch that turns them off all the time which is when it is pushed into the left. Then, when you even it switch out (think seasaw) they turn on when you unlock or open a door. THEN if you do what i did push the right side they are on all the time. Damn i drove all the way home with 'em all on looking like an idiot. I was trying to hide behind my tint but it didn't matter is was so BRIGHT
Old Aug 5, 2010 | 12:30 AM
jdmap1's Avatar
5th Gear
All interior lights are size 168/191. Looks almost identical to the oem bulbs but in LED version. Ur eBay listing does not show the bulbs size u r getting. All it shows is u r getting 6 LED bulbs. Idk what u r doing wrong but I just did mine 2 days ago and have NO problem whatsoever. I did 9 total. 2 front dome, 2 rear dome, 2 front door, 2 license plate, and one trunk.Not a single fuse blown.
Old Aug 5, 2010 | 12:36 AM
jdmap1's Avatar
5th Gear
eBay search 168 led or 194 led. Whaaalaaaa. All kinds of listings for u.
Old Aug 5, 2010 | 02:34 AM
Hi speed's Avatar
runnin a little boost
Buy from Vleds, I bought mine and they have been perfect since.
Old Aug 5, 2010 | 05:14 PM
05TLOwner's Avatar
7th Gear
Finally got it done. Thanks for all the help guys.
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
