AT Preventative Maintenance & Upgrade
Old Mar 20, 2014 | 09:01 PM
The Sarge's Avatar
200k and trans hesitating a little. Considering having all the sensors swapped, flush at fluid and possibly change to a magnafine filter and add a trans cooler. How much am I looking for all the parts and liquids?
I live in an apartment complex that doesnt allow working on vehicles so I would likely have someone do the work for me. But wanted to get rough estimate on parts prices.
Old Mar 20, 2014 | 09:35 PM
VaPouR's Avatar
When's the last time you changed the tranny fluid? I felt hesitation from 2nd to 3rd (50-60kmph), under low load. If I added gas, the hesitation will stop and it will shift into 3rd. Naturally, I blamed the pressure switches and went to my mechanic to get a quote. He advised me that I would be pulling a code if my pressure switches were bad, and not to worry. Instead he said to try a tranny fluid flush, to my surprise it was BLAAAAACK. Well, not really, but it was very dark. I had recently purchased the car so it was on my list of to-do's anyways. And what do ya' know, I've yet to feel that same hesitation since the flush. *knock on wood* Now I'm not saying that it couldn't be the switches, I'm not saying my mechanic is right or wrong, I know we have issues with our transmissions and those pesky pressure switches but I'm just letting you know from my experience. TBH, I'd rather spend the money on a transmission fluid flush and see if that remedies the problem. But, to each his own.
Old Mar 20, 2014 | 11:21 PM
The Sarge's Avatar
Purchased the car and dont know if the previous owner ever had. Its doubtfull, its throwing an ODB code and I need to get it checked to see if its one of those switched. Its just a little bump between 2nd and 3rd. Here in Houston I often drive in stop and go traffic and dont want it to get worse.
Old Mar 20, 2014 | 11:59 PM
TL Luver's Avatar
2006 6spd
i ran amsoil atf in mine and ran it hard...service manual calls for it to be changed at 90k & every 30k after that...
even acura told me not to worry about trans filter actually told me that i may cause the seals to leak due to it being closed up and sitting in its specific position for so long...
Old Mar 21, 2014 | 12:10 AM
The Sarge's Avatar
so leave the filter in and change the atf fluid only?
Old Mar 21, 2014 | 06:21 AM
erdoc48's Avatar
06 Anthracite TL
I'd change the ATF and switches and probably stop there. You likely don't need a transmission cooler or the special filter. You could do the tranny filter (OEM) as well, and it's actually pretty easy to do.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
LeVeL
Oct 18, 2015 04:19 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
