Preparing to do black roof vinyl, need some tips!
Old Nov 30, 2009 | 04:29 PM
t3hanarchist's Avatar
Need a few pointers:
1. how do you take the roof welding along the doors off?
2. what is the best way to cut it if i leave the xm antenna on?
3. does vinyl expand when you put it on? cuz i was planning on making an outline of the cut with pieces of paper taped together to cut the vinyl w/o actually measuring it to the roof.
TYIA
Old Nov 30, 2009 | 09:06 PM
AckTL05's Avatar
Former Sponsor
not sure about the other stuff but I feel like those black things just snap off like everything else on our car.
Old Nov 30, 2009 | 09:10 PM
Steven Bell's Avatar
You know, you can buy these pre-cut. I think BlueBatmobile.net carries them.
Old Nov 30, 2009 | 09:14 PM
im short on budget his cost 80 i got enough vinyl to do the roof and grill w/ a bunch leftover for 35$
Old Nov 30, 2009 | 10:22 PM
DeathMetal's Avatar
Fearless DIY Guy
Claybar before application to ensure you don't have any fine particulate on the roof
Old Nov 30, 2009 | 11:25 PM
AckTL05's Avatar
Former Sponsor
where did you get it from?
AckTL05's Avatar
Former Sponsor
where can i find this?
Old Nov 30, 2009 | 11:49 PM
CLtotheTL32's Avatar
Does he really? If so I would buy one for my WDP in a heartbeat.
Here's his PB....I don't see a roof overlay
http://s2.photobucket.com/albums/y42...TL%20Overlays/
I got a Meguairs Clay Bar Kit at Walmart for under $20. It comes with two pieces of clay, spray bottle of cleaner to use with the clay, wax for sealing afterwards, and a microfiber cloth. Here's a pic:
Old Dec 1, 2009 | 12:20 AM
KB1Spec's Avatar
If you are talking about the railings, you just snap it out. Use something plastic and flat the jimmy it out.
I believe the antenna is double sided tape. So use something flat and jimmy it out gently.
Best is to clean the roof with mixture of soap and water and then use a clay bar and get rid of any residue and dirts. It's good if you have another person to help you out to lay the vinyl on the roof. When you start peeling the backing of the vinyl keep spraying with the mixture of water and soap all the way. Once the vinyl are completely on the roof, use a squeegee and squeegee out all the water and bubble. It is good if you do out on a sunny day. IT WILL NOT STICK WELL if you are doing it on a cloudy or a cold day. So do it on a warm and sunny day. Good luck
TYIA
Old Dec 1, 2009 | 12:54 AM
AckTL05's Avatar
Former Sponsor
would this look wrong on a anthracite car? I have my grille painted black and blacked type s tails mod, and I painted my A in the back black already too..
Old Dec 1, 2009 | 01:45 AM
KB1Spec's Avatar
Umm....you can try Matte Black vinyl top. I did my in semi gloss black vinyl and my RL is graphite pearl.
Old Dec 1, 2009 | 01:49 AM
Phambam12's Avatar
Phmbm12
dang if its 80, i'll gladly buy it now
Old Dec 1, 2009 | 04:38 AM
nfnsquared's Avatar
The XM antenna is bolted to the roof. You'll need to remove the headliner to get to the nut and antenna connection.
Old Dec 1, 2009 | 11:10 AM
KB1Spec's Avatar
^ Thanks for the correction. Sorry I did a few other vehicle and they were double sided tape.
Old Dec 1, 2009 | 12:34 PM
J30A4's Avatar
5th Gear
going to look sweet!
Old Dec 1, 2009 | 02:09 PM
bhavin3623's Avatar
u dont have to take the whole headliner off to access the bolt either..i think there if u take that light housing off u can get it from there but it will take time bc its in a hard to get place.
Old Dec 1, 2009 | 03:52 PM
metrodecals.com
great vinyl for really cheap
Old Dec 1, 2009 | 07:39 PM
Jesstzn's Avatar
He sels them .. I have one of bluebatmobiles on mine .
Old Dec 1, 2009 | 07:49 PM
Jesstzn's Avatar
Thats not correct ... to get them off you tap them with a hammer and a piece of wood from the back ... they will slide forward about a 1/2 " and release from a "T" shaped post then there is 5 clips that the plastic strip rolls out of .
The full how to is at the bottom of this thread
https://acurazine.com/forums/3g-tl-2004-2008-93/front-rear-door-panel-handles-wstrip-glass-window-regulator-removal-3g-garage-f-016-a-603296/
Old Dec 1, 2009 | 10:47 PM
https://acurazine.com/forums/showthread.php?t=603296
in that post it seems like the molding at the windshield is attached more intricately, with your method, does that just detach the section of the molding along the roof?
Old Dec 1, 2009 | 11:30 PM
Jesstzn's Avatar
When I did mine I did it in my garage and I only unclipped the 3 on the roof and left the ones on the A pilar then just tied the srip up out of the way with a string to the garage rafter .
Old Dec 2, 2009 | 12:01 AM
LessisBestmakingendsmeet's Avatar
Hello!
I don't understand this trend. Does not belong on every car and doesn't work so well on sedans.
Old Dec 2, 2009 | 12:17 AM
Phambam12's Avatar
Phmbm12
was it hard to get it perfect onto the car?
Old Dec 2, 2009 | 08:36 AM
dwb993's Avatar
It doesn't have to be understood---only acknowledged and (hopefully) appreciated.
I think it looks great, especially on the lighter colored cars---WDP, ASM/SSM.
The best thing about is that you can easily remove it and go right back to stock.
OP, I have seen the metrodecals site and I am considering them. The BlueBatmobile ones come pre-cut and are a pretty easy install, from what I've seen. Please post your installation experience for us all to see.
Old Dec 2, 2009 | 08:37 AM
Jesstzn's Avatar
Not at all ... Its best tho if done in a garage etc with no wind or crap blowing around.
Old Dec 2, 2009 | 10:01 AM
Phambam12's Avatar
Phmbm12
any tough air bubbles?
Old Dec 2, 2009 | 11:09 AM
Jesstzn's Avatar
Not a bit .. just keep the surface between the overlay and the roof well lubed with soapy water and I used a credit card with a M/F cloth folded over it to squeegie it out .
Old Dec 2, 2009 | 11:59 AM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
Vinyl VS Paint 101:
If anything happens to vinyl you can always take it off.
(Scratches, rips, fading, swirls ect)
Before selling car you can remove vinyl.
With paint.. Cost's more to get it done correct the 1st time.
Any swirl marks, chips, fading in most cases will result in repainting the roof.
If you sell the car and the next potential buyers hate the look your SOL.
Taking care of vinyl:
Now you would want to use any "High gloss" wax for instance I use this
Meguiars Professional series high gloss number 26
http://meguiarsdirect.com/detail/MEG+YELLOW+16
And finish it with a sealer which is:
And use Colinite 845 WAX/SEALER to give it a very wet look and keep it sealed. 1x a month if your busy but 2x a month would be better.
Another member here uses:
Vanilla moose glaze and in which he added:
"Yes .. Glazes usually have a bit of cleaners in them and do a lot of filling of very minor imperfections like hazing .. In the case of the vinyl roof you apply it inthe shade and remove it with a very soft M/F towel."
Exceldetail one of the sponsors in the detail forum here carrys the line.
How to install vinyl:
Here is a DIY
http://auto.badtziscool.com/how-tos/...-roof-overlay/
btw.. the DIY link is chopped.. Hopefully this one will post.
Important to clean the roof off and keep it wet as you go to install the overlay. A credit card with smooth edges and an X-acto knife you can pick those up at ACMOORE stores
www.acmoore.com
find a store near you.
I would suggest a helper, and remember vinyl is paper thin.
Ok where to buy?
Ordering Vinyl overlay:
www.stickercity.com
BTW This is the direct link to the overlay
http://www.stickercity.com/48-black-...for-hoods.html
From sticker city the size of sticker needed:
"BTW I measured our roofs i got 3'8.5" X 4'8"
I got the 48x72 (4x6) roll since i measured our roofs to be basically 4x5.
If you live near Jersey and don't want to attempt this contact my friend:
Applied Film Technologies
725 Fairfield Ave (rear garage)
Kenilworth, NJ 07033
cell: 973.477.6717
OR google a shop near you that deals with tints and overlays.
To remove your XM Antenna
https://acurazine.com/forums/3g-tl-2004-2008-93/how-remove-xm-antenna-709444/
MY orig. thread on overlay with lots of questions and answers
https://acurazine.com/forums/3g-tl-photograph-gallery-96/wdp-reppin-black-roofs-643074/
And last but not least the results with using correct waxes the overlay looks like paint
My detailing thread:
https://acurazine.com/forums/3g-tl-photograph-gallery-96/zano-paint-cleaner-swirl-removal-1z-einszett-polish-colinite-845-wax-sealer-%3D-sex-719328/
I never removed those rails, I just rolled the overlay under the rubber part of those rails. c
Old Dec 2, 2009 | 03:58 PM
Thanks for that post! Helped soooo much
Old Dec 2, 2009 | 04:38 PM
myron's Avatar
04WDPSeDaN- that link is very good that you posted with the DIY, I think I can do this myself next year. I was gonn apay someone this year to do it for me but he didn't have a piece big enough to cover the whole roof and I didn't trust him enough to do it properly with 2 pieces.
Old Dec 2, 2009 | 09:21 PM
TimTim's Avatar
RETIRED
Kudo's 04WDPSeDaN!!
Old Dec 2, 2009 | 09:23 PM
TimTim's Avatar
RETIRED
Broken link.
Old Dec 3, 2009 | 01:05 PM
HigdonTL05's Avatar
anyone have a pic of a ssm with the black roof?
Old Dec 3, 2009 | 01:46 PM
ZhenyaF's Avatar
Off roading in his
Here are quick iPhone pictures of mine
Car is very dirty due to nasty NY weather
Old Dec 12, 2009 | 07:08 PM
Blue Batmobile's Avatar
You're right Steve
Email me to order.
Bat™
Old Dec 12, 2009 | 07:12 PM
dave_ramkumar's Avatar
2011 ZCP E92 M3!!
wow i never knew it was done like that..i always tought ppl just paint the roof black
Old Mar 7, 2010 | 10:46 PM
DoostyTL's Avatar
how does the Roof Vinyl Overlay hold up when going into a car wash ??? will it scratch
Old Mar 8, 2010 | 12:13 AM
MpegtwoTL's Avatar
hmm. not so sure if i like the look unless a matched hood was also done.
Old Mar 8, 2010 | 08:35 AM
Jesstzn's Avatar
Its a lot softer that cleat coat so it may mar in a brush car wash .. then agin .. paint does too .. I avoid them ...
Old Mar 8, 2010 | 08:37 AM
Jesstzn's Avatar
We are working on a hood overlay right now.
