Premium Fuel Question
I did a quick search and didn't find much so pardon this quesiton if I didn't search the right string.
I just went from a 99' to a 08 TL and have a question about fuel. I had to have the plenum removed 2x on my 99' to have the EGR cleaned at a cost of over $500 each. The mechanic (not dealer) told me it was due to poor fuel and thought I should have been using Premium since I was using Regular fuel.
Does anyone know for sure what is the right fuel to run in my 08 that will keep this problem from ocurring again?
I would say first of all premium fuel is required for the TL. Second I would recommend using Shell fuel, it has been known to run cleaner leaving no carbon build up. Texaco is owned by shell so that would also be good. I have seen alot of people on here that use shell with good results.
Head a da Family
Check out www.toptiergas.com.
Click on RETAILERS for a list of brands that have a certain minimal amount of detergent additives in them. Different brands are available in different areas. Shell is the only one on that list that's in the NYC area. I use Shell V-Power exclusively because it also seems to give the best throttle response.
with the 10% ethanol in gas these days- combustion is a really dirty business.
Leftover unburnt fuel particles and fuel additive remnants are everywhere
Removal of the intake manifold and cleaning of the egr passages and ports is a 2 hour DIY that gen2 cars have to do every 75k miles
Why should gen3 be any different?
Yes the TL is odd in this need- but they made small passages compared to other cars
Teir1 gas helps a lot- but is not a cure.
Use of a fuel cleaner like redline or seafoam and intake manifold cleaning with seafoam or wynns or bg44 will help keep the injectors and intake clean, but the exhaust still pumps crud thru the egr ports while the engine is running,,,constantly putting residue thru them. (except at idle and full throttle- then egr shuts off)
add to that:
The PCV system sends oily vapor from the engine direct to the intake snout- need to keep the TB plate cleaned of that for best performance
carb spray or tb cleaner is fine
add to that:
the high compression engine requires a minimum of 91 octane
if they only sell 93 or 94 where you live- thats what you use
91 is a minimum rating for premium
91 octane minimum...don't try to skimp here.
Chapter Leader (San Antonio)
Shell has the cleanest gas at the moment.
Make sure to have a minimum octane rating of 91. Even if you wanted to "save money" you will end up losing money because lower octane fuel will make you lose power in your car and worsen your fuel economy. I have a 98 TL also and always have had Premium fuel, once gas prices sparked my mother decided to put regular which downgraded fuel economy and power, luckily, I realize that she put that in and told her to change than I put some fuel cleaner inside just incase it made the fuel injectors/gaskets dirty.
AZ Community Team
Received 7,770 Likes
Unregistered User
And some people (on these boards even) have done real life experiments and found that using Premium is more cost effective because it's more efficient and will give you better mileage on less gas when compared to Regular.
So treat your car/engine well AND save money.
Registered Member
Registered TL Owner
I only use shell or chevron. Someone on this board was suggesting that using both (at different times of course) is a good idea, becuase they have different addatives in their gas so what chevron doenst clean up shell might be able to and vice versa
Shell- now with Nitrogen added!
ShelaxronCo oil company?!
I do a lot of short trips around the city with moderate to heavy traffic, and my mpg isn't great as a result (about 16 mpg). So, using premium is unnecessary, as mid-grade (89 octane) is good enough. When I go on long trips on the hwy, I always fill with premium gas, which gets me over 30 mpg!!
What it actually means is they have not paid to be added to the Top Tier marketing web site. A lot of other majors have chosen not to pay to be added as well, including the one I work for.
RPF1+RS3 FTW
![No](https://acurazine.com/forums/images/smilies/no.gif)
I only put in 87 once, when I pulled into a gas station and that was all they had. So I only put in half a tank and then drove to another station and put in another half tank of 93. That should average out to 90 octane which is acceptable.
I've said this before, and I'll say again.. that Top Tier website is a marketing gimmick.
All fuel when loaded on to fuel trucks leave the same hose. The difference between gas are the additives added by each brand.
But yes throttle body cleaning is a good and necessary process. I remember I use to clean the throttle body on my 2G TL every 20K (I enjoyed taking it apart, lol)
Unregistered User
I'm also a believer that premium is more cost effective than regular since your engine is running more efficiently and thus using less fuel. Good for your engine and also cheaper in the end.
Full of water...
i learned on MythBuster that putting moth balls in the gas tank will increase the octane level...i am going to try and let yall know what i find
![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
![Drag](https://acurazine.com/forums/images/smilies/drag.gif)
Just like our BMW, the sensors in the car aren't retarded and know to make the engine run fine on unleaded. My family's done this for years and never seen any issue on any of our cars that said Premium Only.
Being an Acha Bacha in
BTW I use Chevron and BP. No Chevrons really up in NY so when I'm in FL I rape it because I notice a complete different throttle feel.
Registered Member
I do the same. I haven't felt or seen any loss of power, and I've done this technique since I got the car in Jan. of '07. I average 21mpg (which is what everyone else seems to manage) in the city, and can get 280 miles out of the tank which is a lot better than some who are only getting 200.
As for running less than 91 octane, which is the recommended minimum for our engines, you will get less power and burn more fuel. But the choice is yours and yours alone.
add to that:
add to that:
lol wut you don't have to do it every 75K. You do it when the symptoms appear....if you really want to solve the carbon problem use quality gas and don't be afraid to romp on the throttle every once in a while, not to mention regular use of fuel additives.....my car has 82K on it and runs like they day it was new...
Trying to clean out
Typically I stick with BP, Shell or Chevron.
On average, there's more load on the engine during city driving.
These things aren't like low compression turbo cars where you can run a lower octane as long as you drive it easy. These are 11.0:1 engines designed for 91 octane. They will ping at partial throttle on less than 91 and many times mine pings on 91 during normal driving.
I've done the research in the form of fuel logs and monitoring knock. Gas mileage is improved using 91 period. The car knocks on mid grade and regular period. It doesn't matter if you can hear it or not, trust me, it's there.
You can't compare your mpg to someone else's to prove a point. It's not a valid comparison, waaaaay too many variables like climate, altitude, driving style, and the type of driving.
The knock sensors are reactive meaning the car has to knock before the sensor can pick up on it and retard the timing. Timing is only pulled for a second and then it's put back in. The TL's ECM is not capable of pulling enough timing to prevent detonation on lower than 91 octane. Trust me, the car is detonating.
In the end, it's your car and if you want to hurt it you can, but I don't understand the reasoning of people saving $2 at the pump only to fill up more often, wasting money in the end.
