Power steering pump
Old Apr 4, 2023 | 06:03 AM
jcook9495's Avatar
Power steering pump
I bought a new power steering pump an it came with 2 black orings. Should I have used those ones or got the black and orange ones instead?
Old Apr 5, 2023 | 09:03 AM
TheSauceBoss's Avatar
Did the pump come fully assembled? In which case, you're referring to the two o rings on the high pressure line that seat into the pump?
I'd use the new o rings, assuming they fit.
Old Apr 5, 2023 | 12:42 PM
GhostTL09's Avatar
Do not re-use o rings.
Old Apr 6, 2023 | 03:24 AM
Igotissues666's Avatar
I ain't right In the head
I would 100% use the O-rings that came with your pump assembly.
Old Apr 7, 2023 | 06:32 AM
truonghthe's Avatar
I think OP was asking if he can use the 2 O-ring already installed on the pump or get OEM one (1 black and 1 orange) instead.
OP if that is your intended question, I would suggest getting a new set from local dealer or online.
Old Apr 8, 2023 | 04:19 AM
mariusz439's Avatar
Damn, what would you do if they start to produce only purple ones.
Brokendreams2008
Mar 27, 2021 01:07 PM
npolite
1G TSX Problems & Fixes
Jan 7, 2021 02:43 PM
austinw2000
Feb 17, 2016 09:12 PM
Sunnybwoy1
Apr 20, 2011 07:45 PM
AcuraCl1
Jan 26, 2005 11:20 AM
