Power Steering Problem
Old Jul 5, 2012 | 01:34 PM
vectorracer's Avatar
Hey guy,
Just had my power steering hose changed due to the recall on the tl's. I have a 2007 acura tl type s auto with 120,000 miles. so everything seemed fine when i took away from the dealer then i notice i sound from the power steering pump after about 5-10 min of driving so i got home look at it and it there is a noise coming from the power steering pump its not a real whining noise its more of a ticking sound with a very very little whine the system is fine it drives fine but the noise is very annoying, iam thinking they ran the pump dry and the bearing or something in the core is worn now, do you think i have any chance to get the fixed at the dealer for free or at a discount or do i need a new bearing for the pump or maybe a new pump entirely which are expenese at 230 bucks. any advice would be appeciated thank you!
Old Jul 5, 2012 | 02:06 PM
losiglow's Avatar
Is there any foaming in the resevoir? It may be that there's a bit of air in the system that has to bleed out. I'd call up the dealership and explain the problem either way to see what they have to recommend. That way you'll also have record of contacting them if it turns out it's a larger problem.
Old Jul 5, 2012 | 02:13 PM
LoveMyTL-S's Avatar
Hmmmm I wonder if they replaced the O-ring.
Old Jul 5, 2012 | 02:20 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
I'd absolutely get on the phone with the dealer. If the PS pump worked fine beforehand it should be the same or better after the fact, not worse. Don't let too much time pass before doing so.
Old Jul 5, 2012 | 02:52 PM
ebelp's Avatar
2014 Jeep SRT
^Exactly. If it wasn't making the sound before, they obviously did something wrong, or the parts they installed are at fault.
Old Jul 5, 2012 | 03:18 PM
There are no bubbles or foam in the system the fluid is at good level an I did the o ring change about 10000 miles ago it's been about a week since I had it at the dealer if the give me problems should I try Acura nationwide? Also since the hose was at fault of puttIng air in the system could it have caused premature wear to the pump? And the hose was under recall I think Iam at least entitled to discount on a new pump at least
Old Jul 5, 2012 | 04:28 PM
Majofo's Avatar
Take it back, make them fix it. Don't pay a dime.
Old Jul 5, 2012 | 05:54 PM
VQPower37's Avatar
^x2
Old Jul 5, 2012 | 08:03 PM
EATSLEEPRACE's Avatar
6SPEED FEVER
Bingo!...I'll would be all over that....
Old Jul 5, 2012 | 11:16 PM
Azndjay's Avatar
MV612
i would of turn around and go back to the service department. No way your messing up my car.
Old Jul 6, 2012 | 12:07 PM
okay so called the dealership agreed to look at my car for free and they wanna see for themselves if it is a power steering pump which is reasonable. so i go on Friday the 13th kinda of a bad day to bring in the car cause of bad luck lol just wanna say thank you to everyone for there advice and ill keep this updated for anyone else that got the power steering hose recall and did it at the dealership please check you PS pump hopefully the same doesn't happen to you.
Old Jul 6, 2012 | 12:31 PM
LoveMyTL-S's Avatar
Dealership is going the right thing, since it's a recall item. Make sure they fix this issue to your satisfaction.
Old Jul 6, 2012 | 03:26 PM
NBP04TL4ME's Avatar
And make sure it doesn't cost you anything out of pocket.
TL-Rocket
Apr 29, 2023 02:33 AM
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
nash3222
Sep 10, 2015 09:46 PM
