Power Steering Problem
Old Jan 19, 2010 | 10:50 AM
Ron tl 2004's Avatar
2004 Tl, had to replace my power steering pump today, 136,000 miles $approx. 600
Old Jan 19, 2010 | 10:59 AM
Bender's Avatar
So there is no more problem? Why did it cost 600 bucks? You could have had a collection of pumps for that amount.
Old Jan 19, 2010 | 11:06 AM
1fsthatch's Avatar
probally installed
Old Jan 19, 2010 | 11:24 AM
nfnsquared's Avatar
Acura doesn't give those pumps away, list is $375.
OP, just a heads up and probably no issue, but keep an eye on your rear seal for leaking. Did they happen to replace the PS hose as well under the PS recall? Don't know if you've seen the other posts:
https://acurazine.com/forums/showthread.php?t=759642
https://acurazine.com/forums/showthread.php?t=759836
https://acurazine.com/forums/showthread.php?t=731001
Old Jan 19, 2010 | 11:57 AM
01tl4tl's Avatar
everyone should check if they are recall affected call acura with VIN 1-800-382-2238x5
And- replace ps fluid as directed by book or more often- iirc its 60kmiles or 3 years
and I know the fluid gets really gunky, causing pump seal failure - destroying rack seals etc
Do a full system flush before installing new pump
Old Jan 19, 2010 | 12:33 PM
nfnsquared's Avatar
There is no recommended replacement interval for PS fluid, at least in the 04 manual. You may be thinking of transmission fluid interval at 60K.
Old Jan 19, 2010 | 02:46 PM
01tl4tl's Avatar
Im gen2 owner so go off that schedule- we dont get ABC service lights, just miles/months,
and from experience in the industry- 3 years is time for those things like brake fluid (should do every year for safety) and ps fluid
Old Jan 19, 2010 | 02:47 PM
01tl4tl's Avatar
it must be in the list of whats in each service? whats your book say
Old Jan 19, 2010 | 03:15 PM
lylen's Avatar
i think i'm having trouble with my ps too. there's bubbles in my fluid in the morning. i wanna say it's my ps hose.
Old Jan 19, 2010 | 03:47 PM
nfnsquared's Avatar
Believe it or not, nothing, pp. 199 and 212:
04 owner's maual.
It does indicate to check fluid levels and condition every other oil change (which is every 10K to 15K, depending on how you drive), but nothing on PS fluid flush/change.
It covers all fluids except for PS and clutch: transmission fluid (service minder 3), brake fluid (every 3 years, pg 211), oil (service minder A and B, antifreeze (service minder 5).
Old Jan 19, 2010 | 05:37 PM
Majofo's Avatar
I'm switching to Redline Syn PSF.. heck I'd use Redline ATF before I went back to Honda PSF.. lol. I would replace the PSF every 30k miles.
Have you had the hose recall done? If not, get it done and make sure they replace the o-ring with the new orange one. If it was done, replace the inlet o-ring, hopefully that'll cure it.
Here's a DIY:
https://acurazine.com/forums/showthread.php?p=11645739
Old Jan 19, 2010 | 10:06 PM
08 NBP TL's Avatar
UA-6
there was a recalled for the 2006 tl power steering. my brothers car is at the acura dealership and the acura warranty covered the whole thing.
Old Jan 19, 2010 | 10:12 PM
subinf's Avatar
One on the right for me
I've had the recall done and replaced the o-ring a second time and still get a lot of noise in the morning. Everything still works fine though.
Old Jan 20, 2010 | 02:44 AM
01tl4tl's Avatar
if changing ps fluid brands you need to do a flush of the PS and rack by filling and pumping out the system twice
Im shocked the new cars are not on a more rigid fluid change
Anyway- based on years of working on cars- 3/60 is time for ps fluid
Brake fluid acura says start at year 3 then every year
I have seen and changed brake fluid on 2 year old acura with grey garbage for fluid- moisture gets absorbed and ruins fluid then ruins parts
fluids are cheap and save money later
a trick used on some older ford explorer vehicles with steering noise- 1 tablespoon of slick 50 in the ps and noise was gone forever,
Old Jan 20, 2010 | 08:22 AM
nfnsquared's Avatar
Brake fluid acura says start at year 3 then every year....
Nope, every 3 years, pg 211.
Old Jan 20, 2010 | 09:46 AM
Majofo's Avatar
yep.
That recommendation is poor. I bought my TL used and when I did my first brake flush the BF looked like swamp water.
Old Jan 20, 2010 | 11:52 AM
01tl4tl's Avatar
I go by severe service for everything- 1 year on brake fluid is time for a change- especially in the dakotas with your severe rain--
wiki hygroscopic and it will send you running to the parts stores for 5 bucks of fluid
These systems hate microscopic rust particles~
acura keeps changing the book year by year so I get things wrong,,yeah- thats it- its acuras fault~
TL-Rocket
Apr 29, 2023 02:33 AM
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
nash3222
Sep 10, 2015 09:46 PM
