Possible to adjust headlights?
Old Dec 1, 2010 | 07:39 PM
robchimo's Avatar
I was in a slight accident a few months back which resulted in replacing the headlight bulb and unit. Now the light does not look like its centered properly. Is there an easy way to adjust this? I'd rather not take it back to the body shop that did the work...
Old Dec 1, 2010 | 07:44 PM
nate_0022's Avatar
Land of 10,000 lakes
Our headlights can only be adjusted up and down, not left or right. There are markers on the plastic panel under the hood by the headlights that says adjustment and you'll need a philips screwdriver to do this. You might also want to check the bulb to make sure it's seated properly into the projector.
Old Dec 1, 2010 | 08:50 PM
mrlal8's Avatar
i had the same exact thing happen to me
it looked so bad from far away one headlights looked dead or completely dim
like the post above...take a phillips screw driver...under the plastic covers is the slot where u put in the screw driver...on top of the plastic it says which way is up and which way is down
Old Dec 2, 2010 | 07:24 AM
VQPower37's Avatar
juss fyi the headlights aren't suppose to be aligned the driver side is suppose to be lower than the passenger side so you wont blind oncoming traffic
Old Dec 2, 2010 | 02:39 PM
borrowman's Avatar
Speaking of blinding oncoming traffic, I constantly have others flash their brights at me. Is this a common occurrence for others, especially since we cannot adjust our lights from left to right? My driver's side light is slightly lower than the passenger side already.
Old Dec 2, 2010 | 02:49 PM
nate_0022's Avatar
Yes this is very commom, for me anyways. Especially coming over hills and what not. I flash them right back. You can always lower them a tad bit more. I'd just leave them at the factory adjustments. It says in your manual how they should be aimed.
Old Dec 2, 2010 | 05:26 PM
MofroS's Avatar
Saysdamnalot
If I drive 20 miles, I will have at least 5 people flash their lights at me. Never fails. I don't even flash back anymore.
hashbrown
Feb 18, 2022 11:20 AM
Mike734
Dec 10, 2021 01:25 PM
Jul 16, 2017 07:33 AM
Mr.Tea
Oct 2, 2015 10:32 PM
