Plasti-Dip Painted Grill
#161
I didn't know you plasti dipped your grill..... I'll have to check it out some time. I did my emblems the other day. My son commented on how nice they turned out. After seeing my rims, he want's to do his on his S2000.
#163
Registered TL Owner
#165
Desert Life Sucks!!
I just took apart the lower grilles also and sprayed those.
I like the way it looks better. More black then grey and its been holding up plus easy to redo if needed.
Looks good gatr
Looks good gatr
wcurrin (04-05-2013)
#169
Desert Life Sucks!!
They all should be 6k. Switchbacks, HID and DRl but they look really blue.
I replaced 8k with these 6k but doesn't look like it. But that pic is just DRL and switchbacks.
I got other pics with fogs and DRL and with HID, SB and Fogs around here somewhere.
SomeWh1teGuy (06-06-2012)
#170
#171
Desert Life Sucks!!
I just got the 3k bulbs couple months ago and that was the first time I turned them on lol. I put yellow overlays on around xmas time.
As far as the housings? They have 31,800 miles on them lol. I am not really happy how they are holding up honestly. The chrome strips inside seem like they are not holding well.
#173
Desert Life Sucks!!
Car stays in the garage unless I am driving it so no. lol
I use the coin op pressure washer to spray off bugs and stuff though. I just stay about 12" or so away to get big stuff and then brush - sponge off the little stuff gently. Dry off and go.
Been holding up pretty good.
LockDots (06-11-2012)
sauceja (06-12-2012)
#182
Starcraft II addict
Has anyone tried clear coating this? Not only to add protection but also to make it have a glossy look. Been thinking of doing the 3M Dinoc carbon fiber vinyl on the grill (did my interior) but this seems to be a viable route and I've played with plastidip in the past. With having my a-spec kit color matched to the car I don't think I'd be a fan of having my grill a matte black.
#183
Chapter Leader (Midwest Region)
^^^ Sean, the makers of Plasti-dip also makes a product called glossifier. This goes over Plasti dip and makes a nice glossy finish. Check out dipyourcar.com they have a lot of cool products there.
#187
first attempt at doing this was an epic fail. took my bumper off as I was changing a foglight, so I figured why not....did it last night in my garage, I was wondering what temperature you all did your spraying because mine came out all rough and ratchet-looking. it was probably around 40 degrees. I watched the videos of the guy spraying the r8 on dipyourcar and it didnt go nearly as smoothly as his..tomorrow I think Im going to try again just taping it off like they did on the website and see how it goes when it is 70 degrees and sunny.
#188
wow, heated up the can a little with a space heater fan and tried the back emblems for s's and g's......makes a huge difference, it was almost coming out clumpy last night. will be doing the grill again tomorrow.
#189
id say go for it i did my rims and liked the outcome i wanted to take a look at how my car would look with flat black wheels i did my grill with trim paint and that crap keeps chipping one of these days ill do it with plasti dip highly recommend if u want to change the look of ur car besides like stated it reversible u can always just peel it off
#192
That looks incredible. On any non black car, doing the whole thing black except for the caliper and/or ring around the caliper looks best. I'm also jealous of the deeper grille on the '07-08; looks much better.
sauceja (04-08-2013)
#195
Received 3,824 Likes
Using Plast-dip as a base worked well too! Few coats of that, then NBP spray can, and then clear!
http://www.flickr.com/photos/87741887@N07/8508784142/http://www.flickr.com/photos/87741887@N07/8508784142/ by http://www.flickr.com/people/87741887@N07/, on Flickr
#200
Thanks guys. I plan on doing the black vinyl roof. If I were going to do CF roof it would have to be real, not a CF overlay. Since that would be a huge undertaking I'm just doing it black. I want to get a quote for having the edges of the hood painted to match the car, meeting up with the grill. Like this (the original pic was all crooked so I had to straighten it and fill in the corners just so it would look somewhat OK):
Wow that looks great!!... the gold gives it a good wow factor!... good job
