Pioneer, Custom Grill & ShortRam Intake Question
Hey everyone, I tried to look and find some answers to some of my question but couldn't really find it. So I have 3 questions to ask.
1.) I have a 2007 Acura TL base model with Navigation. I bought a AVH-4200NEX Pioneer and got the double din kit from KrankIt. Is there any way I can get it install and able to keep my navigation on? Also when you take out the car battery you have to enter the passcode to get everything active again. Is there a way I can still enter the codes with my pioneer?
2.) I want to change out my stock intake but where I live rains a lot so I don't want to install cold air intake cause I don't want to hydrolock. What's the best short ram intake I should get?
3.) I want to install a custom front grill for my bumper but I also want to be able to have Acura emblem in it. If anyone have a custom front grill bumper with the Acura emblem on their TL's please post a picture of it so I can get some ideas.
If you have Navi remember to install a 68 ohm resistor on Pin# 13 & 26 on the 26 pin grey plug from the back of the radio.
You can refer to this thread if you need some help as I did: https://acurazine.com/forums/3g-tl-a...io-car-866385/![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
3. These would be your go to threads for ideas on grille modifications:
--> https://acurazine.com/forums/third-g...s-pics-748647/
--> https://acurazine.com/forums/3g-tl-p...s-here-618755/
Alternatively you can grab one of the C-Mod/Shark Mouth grilles from Bruce (AckTL05 on Acurazine). Here's the links:
--> Shark mouth style acura tl front grill Regular Paint-able Version (Comes flat black)
--> Shark mouth style acura tl front grill Carbon Fiber Version
All those grilles require cutting of your front bumper. There are some DIY threads on here as well.
I have a short ram and don't notice any negative effects of heat soak. Some cold air still gets in via the remaining old stock intake tube coming from the bumper. Aside from that, i definitely enjoy the new engine note and power. Not to mention extremely easy to remove since a ton of stuff is around that area. I have the injen nanoweb filter attached to some common short tube which is also very easy to clean and dries in minutes.
EvilVirus (10-24-2016)
I didn't say having a short ram gives you instant heat soak. I'm saying that whenever the TL suffers from heat soak due to an extremely hot day, etc then the placement of the short ram would not be in the most ideal location. It may affect performance more than where the normal CAI is positioned.
data logs SHOW this information especially since the IAT is right next to throttle body.
mrkingstonvi (10-24-2016)
Definitely not noticable however IMO, unless you have these data logs to back up this claim. I redline my TL all day long, never noticed any power loss from retard or "pull back". And this is in hot humid +40*C weather all the way to minus -40*C Canadian weather.
