PIAA Yellow fog lights issue !
whats up guys? i have an06 tl , went ahead and i ordered the PIAA Yellow bulbs 9006 part # on box says HB and i think at the top is says 131 , anyways i take out the stock fog bulbs and the 3 pieces that twist in are bigger on the stock bulbs and on the PIAA one they are smaller and i cant get the bulbs to fit correctly i guess u can say because i guess it doesnt have enough of a tab to lock it in place ... any one have this issue ? do i have the wrong bulb or what ??
thank you in advance
Sorry---I did a bit of research and it looks like HB is some sort of hybrid type bulb that fits both a 9005 and 9006 socket (I may be wrong on this). Can you return the bulbs for an exchange to 9006?
They definitely were not 9006. Like I said, HB is supposed to fit 9005/9006, but obviously that is not the case.
Also note that H11=9006. I see you can order the PIAA Plasma Yellow in H11. Try that and they should fit no problem.
thanx
I saw it on a site that explained bulb sizes somewhere. I know it is true because my Accord fogs came with H11 bulbs and they are a direct swap for my OEM fogs (06TL, same as you).
mada51589
Jan 9, 2025 04:40 PM
sockr1
Oct 1, 2015 01:31 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
