PIAA wiper Owners
PIAA wiper Owners
I've got these in my cart at Amazon but have some questions. Do these require any kind of adapters to mount? I have a 2005 TL.
Also what kind of maintenance do you recommend to keep the silicone optimal long term? Do you need to apply the window prep pack regularly or just wipe the wipers down?
PIAA 95065 Use with C1 Adapter
PIAA 97048 Use with U Adapter
Does the prep pack come with the wipers? I wasnt sure based on some of the reviews. Thank you
If you want to really do it right: Combine an Aquapel treatment with the silicone wipers.
Skip the prep pack. Clean the windshield with glass cleaner, clay it, and follow up with an isopropyl alcohol (or CarPro Eraser, Gyeon Prep, etc) wipedown. Then apply Aquapel to the windshield (follow the instructions on the package). Install the PIAA inserts and run the wipers dry for a minute.
Aquapel + PIAA complement each other perfectly. My windshield beads for at least a year after they're installed. It would probably last even longer, but I tend to renew both before the Florida storm season each year.
yes each wiper come with a prep pack. OEM blade is garbage, I replaced oem blade once it lasted about 3 summer months here in TX. Michelin premeium blade or PIAA blade is the only I use now.
The OEM inserts are ok, but nowhere near as good as the PIAA super silicone. With the OEM inserts I have to keep reapplying RAINX every few weeks. With the PIAA I never have to reapply. On one of my other cars, the same PIAA inserts were on for 3-4 years and the windshield still repelled water. I've never had the OEM last more than a year, even when I used the JDM inserts. They start streaking within about 9 months for me. (And I regularly clean them)
Bosch Icons are complete crap. They started chattering on two of my cars in less than a month. I only run PIAA now.
Thanks all I went with the PIAA Super Silicone. After applying they did squeak a bit at first and the application wipes left some smearing on the windshield. Ran some water from the hose a few minutes later and it is silent with no squeaks or noise running dry! Excited to try them out when it rains.
Video of the wipers after install:
Installed a set on my daughter's 2014 Jetta. She had PIAA blades on her previous Jetta TDI, and she loved them. Now,18 months later, they still perform well. I normally get at least 6 months service, from OEM inserts, so for what the PIAAs cost me, I could keep my car in blades for 10 tears!
for me, the big difference is that the OEM inserts are shit for heavy rain. You can use RAINX to make it better, but I keep having to reapply every few weeks. With the PIAA blades I never had to reapply for the rain to repel. So the PiAAs performed orders of magnitude better for me in heavy rain.
I installed a set from Les Schwab that are working great. Anyone notice on their set that the connections are not very secure? on mine the plastic connecting piece comes off the wiper arm with a simple downward tug. Other wipers I've installed require a good amount of pressure on a release tab.
vincentliwf
Jan 19, 2006 01:54 AM
