Pause with shifting from Park to Drive, etc..
Old Oct 2, 2012 | 12:17 PM
summit21's Avatar
So my wifes TL has had a very noticeable pause (at least 2 sec.) when shifting from park to drive and/or reverse for at least a year now. I thought the tranny was having issues, maybe needed replacing the pressure switches?? Well I changed the spark plugs the other day after finding them very cheap from Advance Auto came out to about $6 plug, NGK Laser Iridium. Her car no longer has the pronounced pause it did before....not sure why as it would seem to be a transmission issue, any thoughts???
Old Oct 2, 2012 | 12:28 PM
Otacon's Avatar
flappy paddles
Mine does the same thing.
Old Oct 2, 2012 | 12:31 PM
Undying Dreams's Avatar
Mine too. Looks like I need spark plugs lol
Old Oct 2, 2012 | 01:37 PM
The MuffinMan's Avatar
Mine does the same thing. If I am on a hill it actually will roll forward and I almost hit things sometimes because it doesn't kick in when I think it should. Now I just take the pause and leave my foot on the brake till I feel it kick. Haha maybe I'll change my plugs. Not sure how that would do it but hey if it worked maybe it will work for others. Did you by chance disconnect the battery while you changed the plugs?
Old Oct 2, 2012 | 01:39 PM
TheLowLife's Avatar
ditto
Old Oct 2, 2012 | 01:52 PM
I hate cars's Avatar
It's 100% impossible. I would not be surprised if people started replacing their sparkplugs to get rid of the delay and then claiming it makes a difference.
Old Oct 2, 2012 | 01:56 PM
parasitius's Avatar
lmfao.. spark plugs.
Okay but in all seriousness, mine never has a delay when I'm listening to a 5.1 surround DVD-A, but playing my iPhone or normal CDs there is a huge lag... So I recommend you order Katatonia's Great Cold Distance DVD-A
Old Oct 2, 2012 | 01:58 PM
summit21's Avatar
I swear the pause is now gone, it was at least 2 sec. before. I am no mechanic, I did replace the battery about 2 weeks ago, but still had the pause. Hell my wife even noticed the pause being absent after the plug change. I am not saying that everyone should go out and change em, but if it's due it can't hurt. I just thought someone might have insight at to why it helped that's all.
Old Oct 2, 2012 | 02:00 PM
What the fuck? He's talking about the delay it takes to shift from gears...R to D or P to D. gtfo ----->
Old Oct 2, 2012 | 02:17 PM
Mine does the exact same thing. Where do I order that DVD-A?
Old Oct 2, 2012 | 02:26 PM
parasitius's Avatar
here
www.amazon.com/Great-Cold-Distance-Katatonia/dp/B000MM1FS2
^_^
Old Oct 2, 2012 | 04:38 PM
summit21's Avatar
Originally Posted by undying dreams
what the fuck? He's talking about the delay it takes to shift from gears...r to d or p to d. Gtfo ----->
+1
Old Oct 2, 2012 | 07:15 PM
Holiday039's Avatar
Mine does the same thing, and i just had my tranny rebuilt from a P0741 error.
Befor the rebuild it would sometimes take ~4-5 seconds
but now its like ~2, I'm starting to think our cars are just like this...
someone mentioned resetting the ecu, would that work?
Old Oct 2, 2012 | 08:12 PM
Dubs_0's Avatar
Mine does it. Was told its normal
Old Oct 3, 2012 | 02:28 AM
Healingduck's Avatar
'07 TL Type-S
I thought this was a standard feature on all TLs.
Old Oct 3, 2012 | 05:56 AM
carbngrytl's Avatar
Mine does the same thing. Dealer told me it was normal and it's typical for a Honda tranny.
Old Oct 3, 2012 | 08:35 AM
TheLowLife's Avatar
*whoosh* right over your head...
Old Oct 3, 2012 | 08:57 AM
DaeHanMeenGuk's Avatar
Old Oct 3, 2012 | 09:54 AM
parasitius's Avatar
I *prefer* the delay. Instead of having to worry about coming to a complete stop first when I'm in reverse and want to throw it in drive, I have 2 extra seconds -- hence I can hit the break AND throw it in drive at the exact time and decelerate to 0 by time the actual shift operation completes
Old Oct 3, 2012 | 10:55 AM
But the problem is you can't do that with the DVD-A in or you won't have the delay. Maybe you can fine tune it by using the tape player. It might cut the delay down but not eliminate it.
Old Oct 3, 2012 | 02:12 PM
Impossible? I would like to know your background on car electronics and engine/transmissions before accepting that response.
Spark plug change could have had the car idle better making the engine more steady hence creating more vacuum running at a steady 850rpm rather than bouncing around with the ecu trying to correct it for bad spark which would cause the rough idle. Therefore when you are slowing down and come to a stop the engine doesn't bog down lower than it should before reaching idle which would let the trans shift smoother and faster once it knows it is at the correct idle point and vacuum pressures are right.
Not saying this is definitely what fixed his issue or if it is possible but I am just thinking about it for real as I know the workings of cars rather well. I think it is totally possible.
Old Oct 3, 2012 | 02:47 PM
JoeChege's Avatar
I read a post by I Hate Cars that the delay is the transmission shifting into third then to first to avoid a jerk. If you're vigilant like I am, you can actually feel two little jerks, albeit very subtle, when you shift into D. I have no idea how that could be attributed to spark plugs though. Mine is usually around ~2 secs. Transmission is one dead horse that IHC has beaten time and time again.
Old Oct 4, 2012 | 01:01 AM
AZP-TL's Avatar
I have the same delay on my 2G TL, pretty sure it's just common to Honda trannys.
Old Oct 4, 2012 | 07:34 AM
parasitius's Avatar
Fascinating!
Old Oct 4, 2012 | 09:43 AM
Where do you people come from? You might want to question your last paragraph for your own good.
Define "Idle better".
Define "making the engine more steady".
Define "bad spark".
Once you look closer at those three things you might begin to realize you're wrong.
You assume the engine was idling bad to begin with. Short of a misfire the plugs are going to have no effect on the idle.
The ECU has very tight control of the idle. The DBW makes the large adjustments. Ignition timing is used for the fine adjustments. Ignition reactions to idle change are measured in miliseconds. What this means to the driver is a rock steady idle under almost every condition.
Assuming the engine "bogs down" (which the OP made absolutely no mention of) it would only be when the car comes to a stop, not while it's moving. This has absolutely no effect on how the transmission shifts. Once you hit the throttle, idle speed and idle vacuum are totally irrelevant.
Now that that's out of the way, let's go back to the original post which made no mention of the way it shifts through the gears, only that it seems to go into gear quicker. On an old car, maybe, and this is a big maybe, the idle speed was raised, resulting in a quicker engagement. The thinner the fluid or the quicker the engine idle, the quicker the transmission is going to engage first gear. However, the idle speed is set by the ECU. You can create a vacuum leak or you can block off most of the air filter. The ECU is going to compensate by opening or closing the throttle and fine tuning with ignition timing and the net result is the same idle speed.
Just an FYI, when you go from Park to Drive, the TL engages 3rd gear and then 1st gear to lessen the shock of engagement. As the 3rd and 4th gear pressure switches age and get out of calibration, the time it takes to go from 3rd to 1st is increased. Resetting the ECU *might* have a temporary effect. The most likely reason for the change is either temperature or resetting the ECU or the placebo effect. When my car is first started and the idle is slightly high, if I put it into drive or reverse it engages immediately. Once the idle comes down it takes slightly longer. Mine has always been pretty quick because I change out my switches as needed.
Something else happened when the plugs were changed that the OP is overlooking or it's the placebo effect. You could almost make a case if the shifting were improved under power but not the engagement from park to drive. It's completely idle speed and temperature dependent.
Old Oct 22, 2012 | 09:15 AM
Define "bad spark".
Old Oct 22, 2012 | 03:14 PM
paperboy42190's Avatar
WTF? I Hate Cars is one of the most knowledgeable members on this forum, what kind of experience do YOU have? Even I probably know more than you. Better watch what you say around here NOOB
Old Oct 22, 2012 | 06:19 PM
alexpat91's Avatar
5th Gear
my car does this, i think its how this tranny was made.
Old Oct 22, 2012 | 07:04 PM
I have been building cars since I was 16. Didn't mean to offend anyone but all I was trying to say is that it is not impossible. Just because I am a noob to this particular forum does not mean I am a noob to cars. I don't even truly believe this was what fixed or made him think it fixed his car. All I am trying to say is that it is NOT impossible. I am one to never say I know more about cars than anyone because you can NEVER know everything and even though I know more than most I still learn something new almost every day. I do not need to defend what I do and don't know about cars to you as I don't care what you think about me and know that you can't do anything to me "around here" for speaking my point of view and trying to make people think outside the box.
Also everything described about why it is "impossible" is based off of a car in perfect running order. You can't fix a fouled plug with ignition control and throttle movement. That is all I was trying to show. Do what you want with that... I don't understand why everyone gets so defensive in these forums. Take a chill pill. One of the great things about debates is that someone usually learns something and with more than one view you can learn to see that electronics and mechanical parts do some crazy things at times that SOMETIMES are very hard to explain/figure out.
Old Oct 22, 2012 | 07:22 PM
Sick TLS's Avatar
**The Catfish**
this is getting out of control... a simple question turned into members attacking other members. To me, this is not what this forum is about. Lets all get along guys
Old Oct 22, 2012 | 07:25 PM
Sick TLS's Avatar
**The Catfish**
Old Oct 22, 2012 | 07:29 PM
Mine does the same thing. If I am on a hill it actually will roll forward and I almost hit things sometimes because it doesn't kick in when I think it should. Now I just take the pause and leave my foot on the brake till I feel it kick. Haha maybe I'll change my plugs. Not sure how that would do it but hey if it worked but maybe it will work for others. Did you by chance disconnect the battery while you changed the plugs?
Take into account this was my first post. I guess my argument is nothing is impossible. I hear that answer way to much coming from other mechanics and yet I am able to figure it out. That was my only gripe. I am by no means calling anyone dumb or assuming I know more than them. I don't know I hate cars so I am not beginning to act like I am smarter than him. I have only heard good things about him.
Old Oct 22, 2012 | 07:30 PM
IamaTL's Avatar
I like turtles
I read somewhere in a post by I hate my cars that by getting 15" wheels you wont have to worry about the 2sec delay or any transmission issues.
Old Oct 22, 2012 | 07:34 PM
Originally Posted by Sick TLS
I wish that was possible Glenn lol. I am a "noob" though so everybody hates me haha. Should've joined here back when I joined vadrive or honda-tech lol. Oh well.
Old Oct 22, 2012 | 07:47 PM
don't worry, you'll earn your place as your post counts go higher! lol
Old Oct 22, 2012 | 07:49 PM
^but why is that sarcasm lol^ I is cornfused. Well I seriously didn't mean to step on anyones toes. Sorry guise.
Old Oct 22, 2012 | 07:50 PM
Sick TLS's Avatar
**The Catfish**
see everything is good now. yay
Old Oct 23, 2012 | 05:12 PM
I mean its sarcasm because you dont need post count to earn your place, just need to contribute helpful and informative posts on the forum.
Old Oct 23, 2012 | 07:11 PM
Sick TLS's Avatar
**The Catfish**
lets just all let it go!!
Feb 25, 2020 09:57 AM
nanos
Nov 12, 2015 08:41 PM
MyGuti
Sep 12, 2015 06:52 PM
kuzdu
Sep 10, 2015 08:42 PM
1Lieutenant
4G TL Problems & Fixes
Sep 10, 2015 08:39 AM
