Painting brakemotive drilled/slotted rotors
Hey guys, purchased brakemotives drilled/slotted rotors and before I install them I'd like to coat them black.. I haven't seen anyone do this which tells me it might not be a good idea. Is this possible to do? If so how would I go about doing so?
Are you wanting to coat the hub, where the rim sits against? or the actual rotor, where the pad gets depressed onto? If its the latter, I don't thing that would be a good idea personally... might create unnecessary friction, or even cause the rotor/pad to get super hot
justnspace (09-21-2012)
Davidsternmustdie (09-21-2012)
Pads will eventually scrape the paint material off the rotor and you'll be left with a regular brake rotor again.
Why anyone would decide to paint an item that gets constantly wore due to surface to surface contact is beyond me.... Makes no sense at all.
Think about how many times you hit the brakes when you drive. Everytime you hit the brakes, your pads are pressing against the rotor and both the rotor and pads slowly deteriorate. Pads wear quicker than rotors, but the rotor still does wear out over time. Not only that, but think about how much heat is generated due to friction. I don't think the paint would hold up.
My first ricer
I had Brakemotive rotors on my Trailblazer SS, I painted the hat part with VHT caliper paint and it started to peel after a while, the zinc will keep it from rusting there, but obviously it gets worn off on the friction area and will rust in the rain but comes right off when you drive. I've heard of people just using plain old Rustoleum with good results, I might have had the VHT on too thick so it chipped easy when I removed the wheels.
yeah man I wouldn't paint them the brakemotive rotors are very resistant to rust I have had mine on for 4-5 months and not a spot of rust.
Question for brakemotive though: The weirdest thing happened to me a couple weeks ago, I was driving and all the sudden it felt like it had a flat tire. I got out of the car, no flat tire so then I checked all the tires for any movement making sure there weren't and loose lugs, ball joints or anything along those lines. There wasn't so I kept driving and eventually it just went away on its own which seemed very weird to me. The next week I was driving with my brother and all the sudden his car started doing the same thing, we were sure he had a flat so we did the same drill and it was like we were having the exact same problem. Then it hit me the only thing our cars have in common is brakemotive brakes. Is it possible for the brake to grab or something that would cause this sensation? It just seems way too coincidental. Just to be clear I am in no way complaining about your product because I love your brakes, I tell everyone I know who says they need new brakes to buy from you. But I am wondering if you have ever experienced anything like this in testing or feedback from drivers.
I can't imagine paint lasting more than a couple times braking anyways. In fact if I wanted to paint the hubs, I'd probably not worry about over spray and just let the pads scrape the excess off.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
