View Poll Results: What Pressure Do Recommend for Best Launch?
PLUS 5 or More PSI
0%
PLUS 3 - 4 PSI
0%
PLUS 1- 2 PSI
0%
Recommended Pressure (35F / 32R)
0%
MINUS 1 - 2 PSI
0%
MINUS 3 - 4 PSI
50.00%
MINUS 5 or More PSI
50.00%
Voters: 2. You may not vote on this poll
Optimum Tire Pressure for Launch
AZ Community Team
Received 7,771 Likes
At the 1/4 mile.
3G TL-S, 5AT.
In your experience and/or opinion, from manufacturers recommendations, what is the optimum Tire Pressure for a good launch.
Temps should be ~55* - 65* F, low humidity.
Romcomended Cold Pressures are 35F / 32R.
3G TL-S, 5AT.
大日本帝国
^ I've heard that as well, and I've noticed that I bog at 23PSI or below, even with tires with a slightly softer than normal sidewall. I used to keep it at 26 for the track, but I'm going to try not lowering at all and see what I can do with 29+.
~Cheers~
P.S. Definitely raise the pressure in the rear to help keep the front planted. Us FWDs, need all the help we can get.
~Cheers~
Oakes
Wash & Wax
10-12-2015 11:17 AM
NBP_BALLER
09-23-2015 08:18 PM
CostcoFanAUS
09-18-2015 06:05 AM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
