Oil issue
Oil issue
I have been using mobil 1 on my 2005. This oil typically lasts 7500 miles. My mid shows required oil change around 5500 miles. I don't drive fast and I know that the mid keeps track of oil changes by the RPM. If this is the case, there's no point in putting in Mobil 1 as opposed to conventional oil. Should change the oil at 7500 intervals irrespective of what the mid shows?
The Maintenance Minder system is more accurate than a fixed service interval. Oil type alone does not dictate the actual service interval as there are many factors that will shorten oil life and require a more frequent service interval, regardless of oil type.
all oil change reminders, in general, are targeted for the "mindless masses", which is 90% of regular folks that would otherwise forget to change their oil.
Nearly all of these reminders are "geared" towards conventional modern oil (non synthetic).
I recommend using your Mobil1 and change it when the MID indicates. Just "suck up" the difference for the sake of convience. I, myself, use Mobil1 with 5,000 mile intervals.
mada51589
Jan 9, 2025 04:40 PM
mugen_kid
Nov 13, 2015 10:38 PM
IIDXholic
Oct 8, 2015 07:53 AM
