Oil, bring on the opinions!
Latent car nut
Received 2,007 Likes
Another oil thread? Really?
![Lock](https://acurazine.com/forums/images/smilies/padlock.gif)
OP, did you even bother to search before posting?
Oil rule #1: Any oil that meets specs and is on sale....
SuperTech is very good oil, it's UOA is every bit as good as Mobil 1.
I used in all my 4 Honda/Acura vehicles. Honda snow blower and John Deere tractor.My Acura has over 360,000 miles and I have been using since roughly 80,000 miles. Both Pilots have over 130,000 miles and the Ridgeline has 152,000 miles. Is this enough proof that it’s good oil?
Latent car nut
The above said, the proofs Walmart oil is "good enough" lay with the certifications the oil has printed on the side of the bottle/jug.
![Smile](https://acurazine.com/forums/images/icons/icon7.gif)
From an engineering perspective, that is exactly zero proof of anything. Why? You're trying to prove a positive (the oil is good) with a negative (no issues, so far...); such anecdotal "proof" is no proof at all.
Latent car nut
Seriously? Why bother answering the question at all; there are at least a thousand oil related threads on this forum (probably many-many more) and literally millions on automotive forums in general. If anything this thread should have been locked after the first post.
Latent car nut
I totally understand and see where your coming from. Unfortunately this is not your personally forum. These type of forums are design to help one another with questions and issues. If you find that member’s questions and post upset you, you should consider if these forums are for you. From an “engineering perspective”, those emotional feelings you have is just your “ elevated ego” coming back down to earth. Seriously, it will pass with time.
The fact is, the moderators on this site routinely lock new oil threads, as they do with "can I use Regular gasoline in my TL" threads. If the OP had just done a little searching the answer would have been readily apparent.
Wow, so focused on ego, is yours hurting a bit?
Latent car nut
I only drive about 10-11k miles a year, so I usually change it every 5k, which puts me at 6 months on the oil. Kind of live by 2 (every 6 months) times a year or every 5k for the miles I drive. Sadly its also 85%+ city.
The following 2 users liked this post by thoiboi:
horseshoez (03-03-2019),
quantum7 (03-04-2019)
Fibonacci
Money & Investing
06-07-2022 04:59 PM
gocrazyw/TL
07-16-2002 05:23 PM
