Offset
Old Mar 3, 2004 | 12:12 AM
daviddww's Avatar
Offset
OK, I am sure this has been covered, but I haven't been able to find it with a search.
Will any 18x8 or 18x8.5 wheel with 5x114.3 lug fit my car if the offset is close to 45mm? Will a 40mm fit? what about a 35 or a 33? Does the website have to say it is specific for my 6sp TL or if all the numbers match will I know it will fit?
Old Mar 3, 2004 | 12:37 AM
cadesigns02's Avatar
The offset isn't necessarily the problem for the 6spd TL's, it's the clearance of the spokes. The 18" accessory wheels are 8.5" wide with a 35mm offset from what I've read, so you can use the numbers as baseline. The key is the design of the wheel face. Sometimes the spokes curve out and allow for a lot of clearance even with a smaller offset, but it's hard to know exactly what will fit without having someone tried it before. To be safe, I would try to stick with a higher offset 40+ and you should be fine on most 18" wheels that are 8.5" wide or less.
neuronbob
23
Jul 16, 2019 10:48 AM
BreezyTL
Jul 26, 2016 12:52 PM
SinCityTLX
55
Oct 11, 2015 01:20 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
bailey24
Aug 31, 2015 05:38 PM
