OEM Trunk Spoiler
OEM Trunk Spoiler
I have a 2005 base tl with no trunk spoiler. I bought a trunk lid with a spoiler same color as my car (white) the one i bought has some minor damage to it. Would you remove the spoiler and install on my trunk or just get the one its on now repaired and swap the whole thing. TIA
I just installed an OE spoiler on my car. I could have ground off the bolts, I suppose, but I wanted to do it the right way. Took forever to peel off the old adhesive using a heat gun and a plastic scraper, but I was able to obtain a clean surface. Used 3M tape and cut it carefully in order to prevent water from going into the holes and into the trunk. Used the 3M tape to create a barrier wall around both bolt holes.
I also put clear bra film where the 3M tape sits in case I ever wanted to remove it. No one takes an hour long project and makes it a five day affair better than me, but at least it's the way I wanted to do it.
Car looks so much better with the spoiler. I've long held that the TL's spoiler is one of the nicest and most understated spoilers I've ever seen on a car; it finishes off the rear so nicely.
says my wife
I admire your attention to detail and going the extra mile Did you install the deck lid or the 'Wing'?
FYI, with that wing holes are mandatory. You'll also need to change the trunk lid springs because that wing is way heavier.
Meltz07 (02-24-2021)
EE4Life
4G MDX (2022+)
05-11-2023 11:30 AM
gsxr_fvr
01-01-2010 01:13 PM
acn684
09-27-2005 08:43 PM
