OEM Motor Mounts
No you don't. Unless yours is cracked or in really bad shape. Those parts you listed are just brackets and rubber booth/cover. I didn't have to replace those when I did mine.
you're completely off, the numbers you listed are only for the covers and bracket as the previous post said. those will last the life of the car, if not more. the actual motor mounts are 8,11, and 13. and theres also more for the transmission mounts.
what are the common symptoms of needing your motor mounts replaced? OP, What is your car doing or not doing that is making you think you need these replaced? I for example believe i might need them because at exactly 1.5k RPM going 40mph i feel a HORRIBLE amount of vibration, like my engine is producing BASS that i can feel right through the steering wheel... it is not my intention to thread jack, i am just looking to see if you had a similar issue?
If u r hearing a bass ir humming sound coming from ur engine bay maybe it might have to deal with ur tranny... How many miles do u have now?
sockr1
10-01-2015 01:31 AM
