oem door visor installation help
can someone who has installed the oem vent visors on the 3rd gen TL help me out? i am having a problem installing the rear ones. i can't seem to figure out how they expect you to get the rear-most clip to go in the channel above the fixed glass. the two front clips go in under the rubber just fine, but how can the rear clip go in if the glass is fixed and cant go down to get the clip in?
visor install
i did the fronts just fine.
the backs just dont make sense. the front two clips go in like the fronts, i get that. but the rear most clip has to go into rubber that doesnt come out above the small fixed piece of glass. it almost seems like the back clip is on the wrong spot on the visor? you guys who have installed these, was there a clip above that back glass?
Retired and Loving It
i have the instructions
yes, thanks, i have the directions. see in step 11 in the larger photo, they show a clip above the small fixed glass? how the heck does that go in?
figured it out
DUHH.
it goes in the rubber channel that runs along the entire top of the door, NOT the rubber right over the glass.
went in fine.
guess i was having one of those moments.
went in fine.
handsom-hustla
11-13-2015 05:04 PM
