OBD II port location
Old Aug 26, 2009 | 02:10 PM
Hi speed's Avatar
runnin a little boost
Can anyone tell me where the OBD II port is?
Old Aug 26, 2009 | 02:33 PM
dwb993's Avatar
Underneath the dash on the drivers side
Old Aug 26, 2009 | 03:57 PM
DanL's Avatar
Yep, it will always be within 3 feet of the steering wheel no matter what car your in (at least US-spec vehicles).
Old Aug 26, 2009 | 04:18 PM
Sal's Type S's Avatar
By hood release/side fuse panel.
Old Aug 26, 2009 | 05:49 PM
wrxyboy's Avatar
1st TL-S on air in
^^^ +1 also be careful i pushed the obd II plug in to hard once and the car's obdII port came undone and i have to hold the back side down while plugging in the obdII scanner.
Old Aug 26, 2009 | 06:22 PM
Hi speed's Avatar
Does the car need to be running to use the scanner on the car? It says have the car in run position, but some error is coming up with the connection.
Old Aug 26, 2009 | 10:13 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
wat are you trying to do? sometimes you have to make sure you ur scanner is compatible with the onboard rom
Old Aug 27, 2009 | 01:07 AM
NAiL05's Avatar
You just turn on Key on aka the second click where all the indicator lights and so on come on. After that it should pull it. If not somemthing is not right lol. Usually it should at least read something.
Old Aug 27, 2009 | 09:57 AM
esco786's Avatar
lol that happened to me too..the car does need to be on in order to make the connection.
OP what are you using? the handheld ones or the PC-OBD connectors
Old Aug 27, 2009 | 01:58 PM
Hi speed's Avatar
I am using a pc based OBD connector, I will give it a try later on with the car on.
Old Aug 31, 2009 | 10:51 AM
esco786's Avatar
99% chance is that it has to do with the driver and/or com port.
also, certain progs don't work right away (use pcmscan it works all the time).
what prog are you using? also did you install the drivers correctly?
Old Aug 31, 2009 | 12:02 PM
Majofo's Avatar
I'm surprised how civil all the posts have been and that no one flamed you.. lol. I saw in another thread about the Devtoaster - Rev App for itouch & ipod.. anyone running this? The plus side is the OBDII connection is wireless. Plug it and leave it.. the Rev App looks legit and robust as well.
Old Aug 31, 2009 | 02:08 PM
Hi speed's Avatar
It was the connection to the OBD plug that was loose. I snuged up the connection and it worked great. I have been trying to data log pre turbo sensor readings to compare them to the post readings.
As far as flaming people for asking questions, I don't see the point. We are all here to exchange helpful info and that sometimes means repeating that info.
Old Aug 31, 2009 | 02:29 PM
esco786's Avatar
wow seems like you're cooking up something nice...pls do share what results you find
Old Aug 31, 2009 | 02:46 PM
Hi speed's Avatar
I am going to take the car out tonight to get some baseline data. I wll post up what I get.
Old Aug 31, 2009 | 02:48 PM
Majofo's Avatar
What program are you running? I just shook my head a little that you asked where the OBDII port is.. Like DanL mentioned.. I've always seen it underneath the dash in the driver's foot well area. So this means you're getting the turbo or just want to run some baseline readouts in case you do opt for it?
Jul 16, 2017 07:33 AM
vpasla1
Sep 17, 2016 07:24 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
malvothegreat
2G CL Problems & Fixes
Sep 29, 2015 08:00 AM
