O2 Sensor replacement
Old Apr 17, 2017 | 03:42 PM
Chris Broadhurst's Avatar
3rd Gear
Just replaced all ignition coils due to error messages and rough running. Because I ran the car for about 30 Km's with faulty coils I may have damaged the O2 Sensor as I now have he check emgine light on and error message P0420 which indicates catalyst issues. Most times this is the bank 2 O2 sensor which needs replacing. Am I correct in my assessment? Any help is greatly appreciated
Old Apr 17, 2017 | 03:49 PM
it can be a lazy O2 sensor, but chances are it's probably the cat.. It'd be helpful if we had the type of car, , year, mileage, etc...
Old Apr 17, 2017 | 04:01 PM
3rd Gear
04 Acura TL 3.2L with 291,000 Km
Old Apr 17, 2017 | 04:05 PM
You can try and replace the O2 sensor or possibly even clean it but be prepared to shell out for the OEM cat if that doesn't work. Cats will fail if the engine decides to run rich for whatever reason and dump a bunch of unburned fuel into the cat. Sounds like the ign coils issue caused this cat error message.
If I were in your shoes, I'd try :
1. cleaning o2 sensor
2. if 1 doesn't work, replace with OEM o2 sensor
3. if 2 doesn't work, replace with OEM cat.
Old Apr 17, 2017 | 04:24 PM
3rd Gear
thank you thoiboi
i will try these and like you say, be prepared for the worst case scenario
