No limit motorsport has the wrong part number>?
So I am trying to order the stock diameter pulley for my 2006 TL. When i go and click on the part for my model it says ehicle
Fitment:04-09 Acura MDX
Engine:3.5L SOHC 24V
Applicatoin Type: Crank pulley: Underdrive stock belt layout
Chassis Code:YD18
Engine Codes:J35A
Anyways i don't want to order the wrong one.. any ideas, other links or explanations would be great.
Chassis Code:YD18
Engine Codes:J35A
ABP_04TL (02-20-2012)
just ordered it. thanks! Any tips on getting the old one off? Should i get some kind of break free or use a torch? Im at college right now and all I've got with me is a small socket wrench kit and no breaker bar..
I did this on my van...im not sure which way the engine rotates on the TL, but im sure it clockwise as well. If you want to make sure, mark your pulley and bump the starter and see where your mark is now. Good Luck
Former Sponsor
Just a heads up the UR stock diameter pulley is no longer available as a UR part. It is sold exclusively to Excelerate and manufactured by UR so you get the same quality but through an Acura specialist.
http://store.excelerateperformance.c.../i-291887.aspx
SUPRMN84
09-02-2015 11:50 PM
