Nitpick...
Old Aug 27, 2004 | 01:03 PM
Aquineas's Avatar
Disproportionate Member
Nitpick...
Has anyone else noticed that the design of the coinholder means that there's always loose change floating around inside the top level handrest compartment after you open the bottom?
Old Aug 27, 2004 | 01:09 PM
Tuetatesu's Avatar
LOL, I have not had that problem yet, but I can see that happening. My coins have stayed in the slots.
JoganJani's Avatar
never stops!
Yes and it also drops in the back when you open the tray. That is why I alwasy keep my change tray in driver side door compartment. Hope you know that it fits in there too.
Old Aug 27, 2004 | 01:35 PM
JetJock's Avatar
I keep mine in the driver side compartment also....coins are easier to reach, and don't fall out.
Old Aug 27, 2004 | 01:40 PM
Novice's Avatar
A: I have the same exact problem. Funny you mentioned it.
Old Aug 27, 2004 | 01:45 PM
cM3go's Avatar
call your dept of transportation and tell them to get ez-pass/speed pass in your state!
Old Aug 27, 2004 | 02:18 PM
timnguyen9's Avatar
I have mine in the driver's side compartment. They also fall out every once in awhile, from closing the door. It does get annoying because the spring providing the pressure is not strong enough. lol
Old Aug 27, 2004 | 02:19 PM
moreace's Avatar
Anthracite Trend Setter
my coins fall out when the holder is in the door. U shut the door a couple times and they all come out.
Old Aug 27, 2004 | 02:20 PM
moreace's Avatar
I got a squeezy oval rubber thing. U squeez it adn it opens up, I keep my coins in there. no problems. Better yet, it fits perfectly in the upper part of the door, that small tray towards the back.
Old Aug 27, 2004 | 03:16 PM
vtechbrain's Avatar
The coinholder idea is neat but my coins also fall out . I put mine in the the side pocket position. My advise to Acura, improve the holder and make it bigger.
Old Aug 27, 2004 | 04:15 PM
JoganJani's Avatar
never stops!
Try comptech or tein they are better
