New guy looking for a 3rd gen TL.
hello all, I am looking to buy my 1st TL and I love the 3rd gen. Everything about this car is sexy to me. I was wondering what if any problems I should be looking for from yr to yr. I found a few 04s and a few 06s in my price range. The 05s I have seen are more $$$ is there a reason for this, or not? I currently drive a 02 ws6, its fast(not stock) and can be modded forever with the ls1. These TLs seem to have a limited aftermarket. From what I have read, there is no hondata support until the 07s? I was looking for a sexy dd. Intake, exhaust and tune it. maybe an audio upgrade and be done with modding it. But from what I have read the "tune" part is out huh?
Thanks everyone in advance for your input. And sorry this post is all over the place. had a lot to say and didnt want to start a bunch of threads....
-Bruce
-Bruce
04-06 have transmission problems. 07-08 transmissions are a little bit different from what I've heard. Performance wise I'd just stick to the intake and exhaust...don't need to tune for that.
If 06 has a made in Japan transmission, you will be happy with it
Whatever you decide get a pre purchase inspection OR if you live near one of these knowledgeable members have them take a look at it. I just bought an 05 and unlike usual I just bought it without a proper inspection. The car was immaculate on the outside and very clean inside. I got it home to find the cabin air filter completely clogged, the air intake filter so clogged you couldn't see daylight through it and the car was struggling to breath. Now, I pulled the drain magnet to find massive sludge build up as if the fluids have never been changed! The transmission being the weak part of the car. If you can find a manual tranny buy that for ease of mind. However, if you can find a car with maintenance records you should be ok on an automatic. Read everything you can on here about transmission SYMPTOMS so you can look for them when you test drive it. Factor in the price a transmission flush , 2 pressure sensors and filter(04-06 cars have serviceable filter). My last advice would be to stay away from any "tuner" car. Always buy an adult driven unmodified car....it will reduce the chances of a "street racer" car. Good luck and get it inspected first!
Thanks everyone for the input. I have read that the til gets 30mpg but only on prem gas. If that is true that is awesome, these cars are quick and with mpg like that, it is the perfect fit for a daily driver.
Op to answer your question here it is.
DON"T let the AT issue scare you from buying a 3g TL, I have an 2000 Accord V6 and the AT in these car are prone to failure much more than 3g TL AT rate. However I currently running on original transmission and the car has 144k miles, shifting is fine and smooth like any other car. I wouldn't worry too much on the AT on 3g TL, just make sure you looking into past service records like carfax or invoice from dealer/shop and see if the service is done at recommended time (first time ATF change should be around 60k miles according to Honda).
As far as transmission tune like changing gear in the diff to make it pick up quicker or better top end is nonexistent, I know that more like for domestic car like Mustang, Vette etc.
There is no quite free flowing exhaust for our car, however you might want to consider the exhaust stage mod locate in the garage there are three different stages 1,2,3. Each stage is getting louder and louder.
all manual cars come with LSD's.
its the autos that DONT come with them.
I would not look at any 04s or 05s.
go for an 06 or up.
a quiet free flowing exhaust? is there such a thing?
coming from a V8, I thought you would no there is no such thing! lol
free flowing = Mandrel bent
and if you're looking for performance gains, I would not do any of the "stage mods". these exhaust mods only provide sound and not a single gain in hp.
the reason i say to stay away from the earlier models is because; an 04 is 9 years old already.
LOTS of little things will start to go out.
go for an 06 or up.
go for an 06 or up.
go for an 06 or up.
GKinColo08TL (01-31-2013)
^yes, changing a jpipe does increase hp.
the members of acurazine have figured out that changing out resonators on the stock exhaust will give you different tones.
they've come up with the "stage" nomenclature
stage 1 represents a deletion of the midmuffler and adding a resonator..
and etc.
and etc.
and etc.
and etc.
save your money for Hondata pro oh wait you guy have 04-06 model, suck to be you guy lol.. Crab man is on top everything so far in this thread.
J pipe is not a "stage mod" exhaust.
Stage 1: MM delete
Stage 2: MM delete, swap stock resonator with Magnaflow
Stage 3: MM delete, swap stock resonator with Dynomax
Stage 4: MM and resonator delete
Stage 1: MM delete
From what I've been able to gather opening up the exhaust doesn't do much on these cars as far as performance goes. They already have a pretty good intake so your not gonna get too much more air going in so opening the exhaust doesnt do you much. Maybe even loose a little bottom end power to gain some at the top end. Also the computers in these cars are aggressively monitoring and changing things so you've got that to deal with too. Unless you go supercharged or turbo I don't see how you can get any real HP. my
^wrong on a few accounts.
opening up the exhaust does free up HP.
but you're going to have to use mandrel bent pipes and not crushed bent pipes.
ALl the stock pieces of the exhaust are crushed bent.
meaning, if you could get better bends the exhaust gas will flow more efficiently
so, what do we have that makes power?
you can replace the stock cats with straight pipes.
again, free path for exhaust = POWER.
so, by replacing the RESTRICTIVE cats with straight pipes, you get an immediate gain.
next up is to replace that restrictive jpipe with an aftermarket jpipe that has better bends.
Also, the jpipe removes the 3rd cat.
so now, you have a pretty good flowing exhaust untill you hit the stock cat back.
replace this with a more free flowing cat back and you will have gains.
the J series LOVES air.
she needs to breathe.
you are correct that we already have a great cold air intake system. but it is restrictive.
the air goes up and down and through the resonator, finally reaching the throttle body.
zachlone (01-31-2013)
justnspace (01-31-2013)
^ as long as you have the other mods to support it!
Just sayin as far as performance these exhaust mods make a lot more sense if your using a sc or turbo. Otherwise your trying to squeeze blood from a turnip. Maybe I'm just jaded from owning cars in the past where the mods could double or more the HP. 320HP to 650HP Supra TT, Fast n Furious baby lol.
Acura_Dude (01-31-2013)
So basically, just drive it. Intake wont do much? JPipe will help, but unless I want a loud car a cat back is out? Is there no mild sounding exhaust? My car sounds stock at idle, no drone ever, but when I smash it even with the cut out closed it gets loud and mean.... Nothing similar with these cars?
My biggest concern is I hate drone, ever! A little louder I can handle, but i dont want to have to scream at the person sitting next to me on the highway.... If you guys say this can't happen, then I will just leave it stock ...
1fatcrxnem1
22
06-01-2018 01:23 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
Rcelestino93
09-11-2015 12:15 PM
