New Dyno! 254.7whp 228 torque
13.2@ 107 on Street tires
Dynoed my car tonight after the recent mods:..-Greddy Evo 2, Sun Auto kit, P2R spacer
254.7 whp....228-229ish torque..6-speed heaven
Temp: 58 degrees
My car made 242whp and 218 torque with just the intake..great improvement i would say...
The 242 was with the type-s wheels..the 254.7 was with 19x8.5 axis hiros = 27lb wheel..
I imagine with the type-s wheels i could see close to 260whp but that is unknown as of now..
I will try to post the dyno sheets later...ran my friends is350 afterwards and from 50 mph kick i pulled about 2 cars on him..
Temp: 58 degrees
Originally Posted by dr_brains510
i like the many kills on the is350. you think if i get the ATLP exhaust, P2R spacer and w/ my Injen intake i'll dyno close to 270 whp or a little less? just curious.
I don't need to see the sheet. Great numbers, but don't hang your hat on them. Every dyno is unique, and seldom are they truely accurate.
So much of the dyno is in calibration, atmospheric conditions, and setup.
Comparing two different dyno pulls, even on the same machine, on different days is like comparing apples to oranges.
HP is measured on the 1/4 track, not a poorly maintained dyno machine operated by an untrained tech.
Back to back runs with the same dyno, on the same day, with same configuration is great way to measure "gains", but recognize, if your base run is inflated, so are your gains.
I don't buy dyno numbers... I know a good tech van make the dyno say anything you want it to say.
well the stock numbers were 224 whp so its about right...with just the intake it ran a 13.9 so the power is definatly there...the track is closed for the winter so ill have to wait till february...
stock 5AT TL-S are capable of high 240's (again, depends on the dyno)
ATLP, CAI, UR Pulley, P2R Spacer ... i bet 260+ whp.... again, depends on the dyno
Originally Posted by BLACKURA_NY
yes you will
some people can say "fake" numbers. but whatever, all dynos are different... and lots of factors....
the only thing i think a dyno is useful for, is doing a pull, adding an exhaust, and doing another pull a few minutes later.... different days & temp also play a HUGE role in #'s
i think the highest N/A TL 6MT was around 261whp, but im pretty sure they had the cats and/or pulley
Originally Posted by type-s09
i will be well over that with the e-shift cats...then its supercharger/reflash time..then i would guess around 350whp..--talk about a fast ass TL! i cant wait!
yes you will
our fastest member, was bklynpanman and i think maybe Dan K... around 321whp and they both had 6MT... but no hondata reflash...
Originally Posted by XxAfG786xX
what are the hp differences between Auto and stick on a dyno? is it alot or just a little? im kinda confused because i dont think a auto tls dynoed yet
so a typical, 04-06 TL stock
5AT dynos around 202whp
6MT dynos around 220whp .. they both have 258hp to the crank, but the drivetrain loses power... its a complicated theory, but you can search the logistics behind it..
Yes, 6MT's are always faster the 5AT, but dont forget about driver error when shifting.. it usually compensates
the only reason, IMO, that types-09 has good numbers on the track is because he knows how to shift REALLY well... important part on 6MT drivers
eehhhh 350whp is pushing it.. MAYBE with a hondata reflash
If you see on my previous post i did say 350whp with the reflash...
255 whp current
E-shift+25
Supercharger+65
Reflash+35
all =380whp...but that seems a lil high but thats what they "supposebly" make...i think 350whp is a conservative number
255 whp current
E-shift+25
Supercharger+65
Reflash+35
oh, and thats also with the HBP (high boost pulley)
the e-shift cats only yield 18hp on 6MT's, and like 15hp on 5AT's
if you are dead serious, and invest all the money for every possible option.... i could see close to 350whp
ACTROS, had 320whp with a 5AT, and NO reflash.. he also had a custom j-pipe
its not so much HP increases.. but HP lost... drivetrain (Transmission) will lose power... the MT generally loses about 10-12% ..so if you've got a 300hp car, a 6MT will dyno like 265-270.. a 5AT will dyno less, like generally 15-18%.. because the torque converter sucks up power... and doesnt let it all flow to the wheels...
94 DC4 RS LSV/Turbo
It will def be a fast base tl...
us type s guys are going to have to step our game up lol... good luck with the charger and reflash
imo you should go for a gredddy ultimate and tune it that way disregard the reflash
btw...my air/fuel readings were around 14.0...seems kinda lean to me but i think thats from the tb spacer
94 DC4 RS LSV/Turbo
^^ x2
unfortunately, theses no base map in greddy, so you would have to do some serious tuning
so if and when I decide to get the charger I am hoping I could make an appointment with them
What's the point, the suspension will not put it to the ground & the transmission gears will look like corn on the cob after dinner.
Honda already defanged the clutch in the 6spd"S" to save the plates & gearbox, so they are obviously telling you something about the cars inability to handle serious power.
^ WORD
BTW SAE corrected chassis dynos are all quite accurate and dont vary any significant amount.
A reflash of the OEM ecu (or any other fuel and ignition management system) is needed if installing a supercharger no matter what.
Does hondata offer a different reflash for the smaller charger pulley. I would think they would reflash the ecu with a map that can handle as much boost as you can generate with the supercharger and then the customer can change the setup without needing another reflash.
Originally Posted by jdmturbosol
^ WORD
I get a laugh at folks that get a good pull one time...
There's a reason you run three pulls and "keep the best" or "keep the lowest" at dyno competitons.
Bears comments are valid too... Curious how beefy the new 5AT is.
And you guys are summing the gains of a vaporware product. Show me a Hondata reflash for a TL-S with a supercharger. Neither a Suypercharger nor a Hondata flash have ever been demonstrated here.
Heres what 255 whp sounds like on a cold night...1st=worthless 2nd=a lot of tire spin..3rd=hearing a modded luxury sedan come by WOT- PRICELESS
http://www.youtube.com/watch?v=Erw0dP6rDW0
