need some AZ knowledge
Old Jul 30, 2007 | 03:26 PM
ebs312's Avatar
Trying to remove some metal air caps that had "stuck" to the air valve of one of my tires, the tip of the air valve, where the threads are, broke off. now there is only the tiny metal "wire" to release air and the rest of the valve after the threads.
my question is, can i replace this part of the air valve without replacing the entire tire AND is this part of the TPMS?
any help on how to replace the valve or what i would need to buy would be appreciated. thanks in advance.
i hope my description was enough to give you a sense of what i was talking about.
Old Jul 30, 2007 | 04:29 PM
Will Y.'s Avatar
Registered but harmless
Sounds like you just need the valve stem, but the tire will have to be removed from the wheel to replace the valve stem.> $10-$20 job (OK, probably $20 since you're in NY). The TPMS sensor should be fine.
Old Jul 30, 2007 | 04:32 PM
6spMike's Avatar
Mike's Silver Bullet
A tire shop will have to dismount the tire in order to replace the valve.
I'm not familar enough with the TPMS to know if that'd be affected.
The metal cap was rusted on? Switching to plastic now?
Old Jul 30, 2007 | 04:37 PM
ebs312's Avatar
thanks for the info guys. hopefully i can just replace the valve and that will be the end of it.
the metal cap wasn't rusted on. i asked a mechanic and he said that usually, metal caps "fuse" onto the valve and cause what happened. so never go with metal caps. i am going back to regular black plastic.
i have another metal cap still on, so hopefully, that can be taken off without damage. i got the other two off without incident.
Old Jul 30, 2007 | 06:08 PM
6spMike's Avatar
Make sure to get the wheel(s) rebalanced when you do it.
Old Jul 31, 2007 | 01:17 PM
ebs312's Avatar
just as an update. i went to a tire place and they said i need to take it to the dealer b/c it's a "special" valve.
oh well...guess i'm off to the dealer to get ripped off.
Chojun
Dec 16, 2015 07:12 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
0opie
Sep 22, 2015 04:15 PM
pgeorg
3G RLX (2013+)
33
Sep 16, 2015 07:40 PM
Billu99tl
Sep 13, 2015 11:30 AM
