Need help with part #
Old Jun 20, 2011 | 06:36 AM
henrokk's Avatar
Ok so I took out my glove box to get to the little isimple box which the installer left behind the glove. When trying to put it back together, those little 10mm bolts that screws the little hinges on the glove onto the large plastic piece refuse to stay in. I'm guessing the threads are stripped. There's a bunch of plastic shavings left over on the bolt's threads. So what is the part number for the plastic piece?
To clarify, I'm sure many of you have changed out your cabin air filter. It's the large piece that you pry off right after removing the actual glove box. That piece is also where the glove box threads onto using the 10mm bolts. Looked over on acuraoempartsdepot.com and I the parts illustration is not very clear.
A little confusing I know, but anyone that has taken that out before should know what I'm talking about.
Old Jun 20, 2011 | 07:19 AM
LoveMyTL-S's Avatar
I don't have the part number, but it may be time to do this mod:
https://acurazine.com/forums/3g-tl-2004-2008-93/cabin-filter-replacement-mod-3g-garage-f-130-a-591437/
Old Jun 20, 2011 | 08:03 AM
henrokk's Avatar
I thought about that but I still needed to take it all out because that's where the isimple gateway is located for me
Old Jun 20, 2011 | 08:32 AM
LoveMyTL-S's Avatar
Perhaps it's item #10 in this diagram?
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Old Jun 20, 2011 | 09:25 AM
henrokk's Avatar
I believe you're right...you're the man I don't care what they say about you
Old Jun 20, 2011 | 10:46 AM
LoveMyTL-S's Avatar
I don't either. Glad to help.
csmeance
Jan 7, 2026 06:25 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Ny1718
Sep 11, 2015 09:21 AM
hand123
Sep 10, 2015 09:29 AM
hand123
Sep 10, 2015 09:27 AM
