Need help for the interior light bulb size!
I am thinking about having all my car interior map lights, dome lights, step courtesy lights changed to Xenon White LEDs.
I have checked the Osram Guide but still a little bit confused about the the bulb sizes I need. Can someone who has did this help me out, thanks a bunch!
I was extremely confused also. I recently took the plunge and bought 6 red leds from Vleds. Two for the doors, two for the front map lights, and two for the rear dome lights. I can't find the thread but someone posted this earlier. 194,168, and 2528 all are the same size connectors but they differ in watts produced. Try and do a search and see if you find this thread. You shouldn't have a problem getting 168,194, or 2528. Although, you will have to make sure the size of the actual LED will fit into the map/dome/door panel. Here is a pics of my LEDs. They came with different adapters in the package. I just used the one was the same as my factory bulb. Hope this helps!~
Here you see the pic of the factory bulb on top, the adapter in the middle, and the new led from Vleds. Specifically they are 30 M-SMT LED.
Ensure your new LED fits in the factory location. Here is an example of the front map lights.
Interior pic at night....
194 wedge base is correct.
Reference this thread for all of your bulb sizing questions: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-acura-tl-bulb-sizes-list-3g-garage-g-077-a-691135/
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
