Need help diagnosing my brakes.
S.3.A
I have an 04 5AT TL. The brakes on it are very inconsistent, some days it feels awesome and has a lot of bite, but other days it feels soft and requires the brake pedal to travel more before it bites and even then the bite just doesn't feel as firm.
This has been the case since I first got the vehicle in August 2010. It's gotten a lot better since I changed my front rotors to EBC slotted rotors and installed Akebono ceramic pads (the rears are not slotted with semi-metallic pads). However, it still happens sometimes (although when it happens its not as bad as before the front rotor/pad change).
Does anybody else experience this with their brakes? Could this be due to temperature? If so, will SS brake lines help make it more consistent? Any help/input/advice is much appreciated!
AZ Track Whore
The overall conclusion on AZ is that the 5AT stock brakes are one of the biggest disappointments with the 3G TL. You're mods are definitely a step in the right direction but I agree that some SS lines and some Motul RBF600 are what you're needing. Temp is the biggest killer of brakes period. little things to help this would be to remove the dust shields on at least the front brakes and maybe consider running a pad with a higher operating temperature.
Or upgrade to brembos lol
S.3.A
This might be a dumb question but I couldn't find anything on google, just curious as to how pricey and difficult is it to replace the stock brakes with brembos? Haha idk if I have the funds to get brembos. Would replacing the calipers with new ones help at all? And also has anyone put on brembos in their auto?
I'm by far no mechanic but if my brakes were inconsistent I would look at air in the line and vacuum problem. I think if you had crappy pads rotors or what not the problem would always be there. You mentioned temp I could see that if the brakes got hot it may lose some performance but I think it would be easy to see if that was the problem with a few test drives after the car has sat over night.
No mechanic just an opinion and we all know how opinions go
AZ Track Whore
A brake bleed is never a bad idea but if there was any real problem with the vacuum lines or master cylinder, the problem would be much worse than what the OP is describing. You wanna see heat ruin your braking, just boil your fluid on the track and watch the brake pedal from a perfectly sound system go right to the floor and do nothing lol. Obviously an extreme and it'd never happen on the street but heat definitely is the brake killer.
OP, do you know how much pad you have left on the fronts?
AZ Community Team
Received 7,771 Likes
D-103: Standard brakes to 6spd/TL-S Brembo Brakes Swap Part List
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/d-103-tl-s-brembo-swap-parts-list-716463/#post10669446
S.3.A
S.3.A
https://acurazine.com/forums/showthread.php?p=10669446
(fixed. BC)
AZ Community Team
A lot of DIY's and FAQ's are organized on this page: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
That's where the Swap List Thread is. This link should take you directly to it:
Fixed the above links as well.
dubxrossd11 (09-05-2011)
S.3.A
A lot of DIY's and FAQ's are organized on this page: https://acurazine.com/forums/showthread.php?t=553554
Also, I just took a look at the Swap List Thread and someone mentioned why not do a big brake kit instead of the brembos.. what's the difference between big brake kit and brembos?
S.3.A
btw just curious, do you have a BBK or brembos installed on yours?
S.3.A
Oh haha I thought you might have done a conversion from the stock 5AT. I probably should've taken a better look at your avatar. Your car looks sick, I want to take mine to the track one day haha just wishing.
GWEEDOspeedo
01-15-2016 10:39 PM
