Need Advice - Possible cat problem
Alright I'm going to try and give as much detail as possible so here goes. I have an engine power issue. While vehicle is idle or slower speeds with light accel it seems to function properly. When I accel harder and higher speed the engine power lacks as well as getting what sounds like a vacuum leak when really getting on it. I have no check engine light on nor does it come on when I'm experiencing the lack of engine power. I did note a couple weeks ago that the 3rd cat sounded like the material inside had come loose and rattled. I also get an noticible sound almost like a back feed of air(belch) imediately after shutting off the engine. I'm leaning toward a restricted/clogged cat but any input would be considered.
lil12002
Jan 25, 2017 06:27 AM
