My Royal Purple Test
I had run 2 consecutive 8,000-9500 mile intervals with Pennzoil Platinum 5w20. I have 114k currently on '05 Base. I caught Royal Purple on sale at NAPA for or $5/qt but they only had 5w30. So after putting that in my car, my engine ran noticably smoother and quieter. I also was getting a good 1-2 mpg. On long hwy trips I would top out at 27-28 mpg with the PP but now I was getting 29-30 consistently. Man that feels good! In stop-go I had been getting 20 to sometimes 22mpg. With RP, 23-24 was normal and now, after 9k miles, I am getting 22-23 city. So still noticably smoother and better mpg.
Now for the test: That was going from PP 5w20 to RP 5w30. Now I ordered Royal Purple 5w20. I am very curious to see A) if my engine runs smoother or not as smooth. and B) a difference in the mpg.
I am very in tuned with my engine and will be able to recall if it is better or worse that the PP 5w20. I'll update later.
I used RP in my previous car, g35. That engine loved RP. It idled smoother, pulled cleaner, and generally felt better. I'm not sure about the gas mileage, 'cause I was always driving it hard.
I just got my Type S - so it hasnt gotten its RP yet. I've bought it though... just waiting till its oil change time.
I'm glad you didn't say the car felt faster with RP. Glad you like the oil! I always tell people experimenting with oil to find one they like and stick with it. Also, make sure you research independent studies on oil so you don't pay too much for something that you could get cheaper with a different manufacturer. Not that it matters, but I'm a die hard mobil1 fan. All of the necessary and unnecessary being said, I'll be watching this thread to see your mpg results as you test. Have fun!
Also, it's a good idea to keep a log of all oil changes and fill ups to see how your mpg averages as your mileage changes. It's good information to have and if you decide to sell, that's just one more thing that says "I care".
You really need to send your oil into a lab and let their results speak for the effectiveness of the oil. Oil isn't really a "seat of your pants" kind of thing......
Blackstone Labs or some other similar.
http://www.blackstone-labs.com/free-test-kits.php
I've always loved Royal Purple, just never enough to pay for it. But we don't want to go all "oil thread" on everybody, eh!
Plus spending $25 will make this oil change about $40+$6+25= over $70.
Oil Analysis would be a great tool to help you understand the wear in the engine as you change oils. It doesn't take too many samples to build a trend, and then you would be able to see the effects different oils have on wear. You may find a lower priced oil offers the same protection as RP, which could help offset the cost of the UOA. Similarly, you may find that you can extend the oil drains, again lowering the cost of your changes.
My theory is that if the engine is not running smoothly, then it is not running as efficiently as a smooth running engine to a certain extent. I do not think that "the thinner you go the better MPG you get only at the expense of wear."
Now I did switch to the Redline ATF about 3k miles before switching to RP. That could also be contributing. The transmission is a resistance to the flywheel thus the engine, and could lead to a more efficient system i.e. better mpg. That is part of the reason flywheel and rear-wheel hp are different.
That being said, as a general rule of thumb you are absolutely correct that a thicker oil would been more resistance and less mpg. BUT I am getting the feeling that smoothing out my engine's performance may be contributing to 1 or even 2 mph when hwy driving. Either way, I am happy about it no matter what the reason! I haven't gotten mpg like this even when I bought the car at 74k miles. And like I say, it has been cosistent for the entire 9, 000 or so miles.
Thanks for everyone's interest, I know I have an interest in the oil research here and even at BITOG sometimes (although I usually don't admit it!)
Also, I do want to mention that I was fully expecting a slight decrease or at the least, no change in mpg. I had been putting 5w20 every time. I do not think I will be able to conclude with some revolution applicable for everyone's car, just mine. I also do not think smoother engine means better mpg, just in my case.
so if you want to put royal purple but your engine currently has something else, whats the procedure to convert it over? Does it need to be flushed or something?(sorry i dont know jack about cars)
I used to run RP 5w-30 on my Cadillac Deville and I was so in tune with that car that I could feel a difference compared to 5w-30 full syn mobile 1 it felt cleaner and smoother in every which way. I cant wait till my TL is ready for her first oil change since purchase to switch to something better then what the dealer put in there. Only a couple hundred miles more. Have you used the RP oil filter as well I heard that was one of the best available right now.
MrHeeltoe
20
02-23-2023 01:54 PM
joflewbyu2
08-18-2019 10:38 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
