My Brake Job Issue
Elegance
My Brake Job Issue
Long story short, I bought Rotora rotors with ceramic CMAX pads from Autozone and my rotors surface got rusty and are now ruined ($400 later, didn't think it was possible).
Now I need new pads/rotors. I like the zinc rotors from brakeperformance.com (slotted or dimpled/slotted) and I also like the CMAX pads that I have had on (no squealing/brake dust).
My questions are here: the rep on brakeperformance.com said don't use ceramic pads as it will wear down the rotors faster, but other people say that ceramic is softer and will wear them down less. Can someone clarify?
I can get a set of slotted rotors (4) for $230 shipped and cmax pads for $95 or dimpled slotted for $340 shipped with free semi metallic pads (or you can upgrade to better semi-metallic for $80). What setup would you suggest?
Thank you,
Chris
Thank you,
Chris
AZ Community Team
Received 7,771 Likes
Can you clarify about "rotors surface got rusty and are now ruined". All rotors get surface rust, it's normal and goes away as soon as you brake.
If you're talking about hubs/edges, etc, those can be painted.
Or do you mean something else?
Maybe pics would help.
Elegance
On the back side of the rotors the rust is so bad, it makes a loud grinding noise when I brake and the pedal vibrates. They are not warped and it was confirmed by my mechanic. I will 100% be posting pics when I take them off my car to put the new ones on.
AZ Community Team
:hmmm:
Something sure sounds wrong; don't think I've heard of that before. In for pics.
How old are the rotors? If they're defective, are they too old to get credit/return?
Elegance
I got them from Excellerate and I had them for about 15 months. They were rusted in spring so they lasted about 8-10 months in good working condition. They can't be turned, but I will wait until I see for myself how bad it is.
Any rust that will accumulate on the rotor brake surface will dissipate shortly after brake application, and yes some will sound rather harsh until the rust is gone.
I've seen pads that were replaced and didn't sit in the exact same area as the pads they replaced, and they will make a horrible sound if the rotor wasn't cut and will continue to make that sound until the rotor area is smoothed by the new pads, and that can take quite some time.
Actually ceramic pads are less abrasive than semi-mettalic, have lighter colored dust, but there are many variations of ceramic pads depending on the manufacturer.
Can't wait to see the pics.
This is just my understanding.. from a lot of reading but I also could have read the wrong things... but...
from what I understand Ceramic does less wear to the rotors because of the material.. semi-metallic and other that "bite" more do more wear to the rotors
one of the reasons why cermic usually costs more that other pads.. well otuside of performance pads
Dont have the articles to back up what I said just years of doing my own pads and research
Holy cow lavo, thanks for the heads up. I was just considering these for the RDX as they supposedly have better stopping power... I'll stick with the factory rotors now.
I certainly wouldn't put any credence into the OP's description or even consider the Rotora to be a problem until we see the pics. Been around a long time and have never heard/seen the pad area of the rotor surface rust as described. I've seen the drilled rotors rust and bleed from the holes/vanes as well as the hat and outer circumference of the rotor rust.
Former Sponsor
The OP sent me an email regarding this. He lets the car sit for extended periods of times outside. Rust/oxidation will build up and be difficult to remove after months of not driving a vehicle. However, the rotors aren't ruined. And the pads should be fine. All they will need is a slight machining to remove the rust and some sanding of the pads. There is no need to buy new components.
Elegance
Regardless if it sits, they should not be ruined, I have drove it almost every day over summer/fall but has not gone away after the damage from the winter/spring.
I am interested to see exactly what they look like, as of now, I am going off what my mechanic told me.
Chris
![](http://www.centricparts.com/images/stories/Friction%20Page%20Update/Graphs/104.jpg)
![](http://www.centricparts.com/images/stories/Friction%20Page%20Update/Graphs/105.jpg)
They make a lot of different compounds (more than shown here)... http://www.centricparts.com/index.ph...149&Itemid=224
FCVadi (12-07-2011)
Yeah, and if I had a dollar for every time I've seen this falsely stated, I'd be a hundredaire.
Ask your mechanic what he measured the rotor thickness to be. I'll bet you he can't answer that question. Why, because he didn't do it. If he didn't measure it, then in no way does he have a clue if the rotors can be turned or not.
But even if the rotors can be turned, I wouldn't, nor is it even needed. Some sand paper and a little elbow grease will solve your problem.
Former Sponsor
My mechanic said they cannot be machined. I can't see the backs, but know that the car vibrates while braking and is very loud. I am interested to see what the back side looks like. Rather than tell him that he is wrong and take them off and have him wait for me to look at them, I would rather just buy new ones and have the job done.
Chris
Chris
mada51589
05-03-2022 08:54 PM
snorf
11-04-2019 06:44 AM
