My 3x3
My 3x3
Ok so I know about all the other threads discussing the 3x3 drain, I just want to check with everyone before i do it being its kinda an expensive thing to fix if i mess it up. This is my plan..
Car has 126k
Bought new pressure sensors for 3rd and 4th gear.
Bought 6 quarts of redline type f
Bought 3 quarts of d4
1. F X F X F
2. F x F x d4
3. D4 x d4 x F
I don't want my trans to lunge just have a good solid shift.
Car has 126k
1. F X F X F
2. F x F x d4
3. D4 x d4 x F
Go with what SharksBreath said. Get jack stands. NEVER....EVER work on under a car supported by just a jack. Always use jack stands.
I also have two jack stands.
When car was hot, I had only the front raised and 3.5 quarts came out.
Second time car was cold, with front raised. Very little amount of oil drained out. So i lowered the car and let the oil drain into the pan, with car on floor. Also got 3.5 quarts out.
I always have the car on the floor when refilling back with ATF.
when is it recommended to replace the pressure sensors? i havent found the information from other threads. i already feel my gears not shifting smoothly and was curious if it would "hurt" my vehicle since its only at 31k. i was gunna do em when i flush my ATF but thats 30k more miles -_-
Hey what's up guys I'm 49000 gonna do 3x3 with all red line type f how long should I wait to do them or what mile intervals also another question I heard there was 2 3rd gear switches or 2 4th gear pressure switches for 2007 type s? Can some one confirm all the parts needed for the 2007 type s? I heard o ring filter 3washers and 3 gaskets (same thing) thanks guys
^you can do the 3x3 all at the same time.
drain 3 qts
refiill 3 qts
drive around and cycle through all the gears including reverse for 5 mins or so
^do that 3 times to get your 3x3 complete.
here is the DIY for the pressure switches...
https://acurazine.com/forums/3g-tl-2004-2008-93/110-b-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2007-2008-a-840630/
drain 3 qts
refiill 3 qts
^ would like to know the answer as well.
thanks for the info, i mean my car is almost 4 years old, if not already 4. from the post above, would it be wiser to swap the switches at the 3rd drain?
no i haven't done a fluid flush yet and the highly doubt the previous owner did anything as well. i purchased the car with about 12.2k miles on her. only service i've done thus far would be oil changes.
Not to thread jack but I am also doing a 3x3 with Switches and had a question in regards to how the 3x3 should be done. Should it be
FxFxF
FxFxD4
FxD4xD4 or
FxFxD4
FxFxD4
FxFxD4
A little confused on that.
FxFxF
FxFxD4
FxD4xD4 or
FxFxD4
FxFxD4
FxFxD4
Stick with F...
That's what I'm doing!
Love Redline Racing Oil F!
vpasla1
Sep 17, 2016 07:24 PM
